animate
animate
Message 1 of 13
animate
I'm trying to figure out how to animate showing the material in the hoses. Also how to move my model in and out for a video clip. New to the situation.
Replies (12)
Message 2 of 13
mcgyvr
@Anonymous  Did you see the video I posted (and reposted after you said you couldn't see the first one) about this?
Do you still need help with that? Where specifically?
That should show all you need to do to create your animation..
Message 3 of 13
mcgyvr
https://forums.autodesk.com/t5/inventor-forum/animation/m-p/9752520#M802238
Message 4 of 13
Yes. But the thing is im tring to do a walk through. Perhaps zooming in and out and  I think im going the wrong way about this.  I also tried putting it in presentation but, it wouldn't import the model because I think its an .ipt and not an .iam.
Message 5 of 13
mcgyvr
@Anonymous
oh boy...
So that image is just a screenshot of a single ipt part file?
Was this just an imported step file or something and you don't even have this modeled in Inventor.
Can you post the actual Inventor files you have here?
If its just a single Inventor modeled part we will need to show you how to use "Make Components" to push out each individual solid into its own part file to create an assembly..
Lets start by getting you a usable model to start animating.. THEN we can work on walking you through the animations. Animations will be next weeks lessons 😉
You need to learn to "walk" before you try to "run" with a full animation walk through. (pun intended)
Inventor is a professional software and requires a professional effort into learning it.
Please post your ipt/iam files of what you have.
And please try to provide as many details as possible in the future to avoid excessive back and forth guesses/assumptions,etc..
Message 6 of 13
I understand and I appreciate it greatly for help. But my file is too big..
Message 7 of 13
JDMather
There is no such thing as "too big".
Place here and the post public link.
https://myhub.autodesk360.com/
Message 8 of 13
JDMather
Studio 18:30
Add Camera 32:30
Camera Zoom 37:00
Message 9 of 13
mcgyvr
The principles in the screencast I posted still apply 100% even if you just want to leave it as a single ipt file..
Just animate another extrusion inside the tube extrusions..
and then start watching videos like..
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/screencast/Main/Details/282870ba-...
and
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Inve...
and
https://www.youtube.com/watch?v=AWd17bD6rgs
and generic stuff like..
Message 10 of 13
Thanks.. I think I found my way just went about it the wrong way
Message 11 of 13
I'm back. how come when I set the camera to link to view this is what happens.
Message 12 of 13
JDMather
Zip and Attach your assembly (or a simplified dummy assembly) here.
Message 13 of 13
mcgyvr
What specifically is happening?
When you check the "Link to View" it updates the active view to match the camera properties and hides the camera graphics
