Inventor Forum
Altium CoDesigner
2 REPLIES 2
szwa6421
249 Views, 2 Replies
Altium CoDesigner
Hi all!
I'm attempting to get the Altium CoDesigner add-in to work in Inventor 2025. I've installed the add-in and restarted Inventor several times. The add-in has 'Loaded/Unloaded & Load Automatically' ticked but when I click 'OK' the add-in does not appear on the ribbon as it should. I re-open the add-ins list and it shows as unloaded, even though I have selected loaded. I click it to change this to loaded and then click 'OK' again but it still does not appear in the ribbon. When I open the Add-Ins Manager, it once again shows as unloaded.
I've looked at several other posts about add-ins but not found anything that helps/anything particularly useful for the 2025 install. Any help fixing this would be greatly appreciated!
Thank you.
Kindest regards,
Sarah
2 REPLIES 2
James_Willo
in reply to: szwa6421
Hi, it appears Inventor 2025 is not supported yet based on this website.
https://www.altium.com/documentation/altium-codesigner/new#supported-versions
James W
Inventor UX Designer
szwa6421
in reply to: James_Willo
Ah okay, that makes sense. Thank you so much James! I'll try 2024 instead.
