Hi all!
I'm attempting to get the Altium CoDesigner add-in to work in Inventor 2025. I've installed the add-in and restarted Inventor several times. The add-in has 'Loaded/Unloaded & Load Automatically' ticked but when I click 'OK' the add-in does not appear on the ribbon as it should. I re-open the add-ins list and it shows as unloaded, even though I have selected loaded. I click it to change this to loaded and then click 'OK' again but it still does not appear in the ribbon. When I open the Add-Ins Manager, it once again shows as unloaded.
I've looked at several other posts about add-ins but not found anything that helps/anything particularly useful for the 2025 install. Any help fixing this would be greatly appreciated!
Thank you.
Kindest regards,
Sarah
Solved by James_Willo. Go to Solution.
Hi, it appears Inventor 2025 is not supported yet based on this website.
https://www.altium.com/documentation/altium-codesigner/new#supported-versions
Ah okay, that makes sense. Thank you so much James! I'll try 2024 instead.
