Adding hole note with dual dimensions
bengee5454
bengee5454
Hi. I am currently dimensioning a drawing for an American customer.  I have to give the dimensions as x.xx [y.yy] (imperial [metric]).
All going well until I use the Hole Note. I cannot get this to display the dims in the correct format. I've tried messing around with the Dimension Style/Alternate Units/Dual format, but nothing seems to work.
A workaround is just to dim normally, then edit the text - but it doesn't feel right!
Anybody else have this issue, or know how to display the alternate units in the hole note command?
Ben
IV 2023
Gabriel_Watson
Right-click a hole note dimension > Edit Dimension Style, then:
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-162B828C-D6BA-4989-AA61-C9F4516D60D7
bengee5454
Below is a screenshot with the following settings:
Shouldn't inches be displayed (the primary units)? Instead mm are given
When I change the settings as you suggest
I get.....
It seems to be reading mm as primary and secondary dimensions
Gabriel_Watson
Inches also don't show the unit here for me, but try check marking this option to show "mm":
Luis_Pacheco_3D
Try to change the format to 1/2 Fraction not Stacked
johnsonshiue
Hi! Except dimensions, I don't believe Hole Note support dual unit. It is because the Hole specs are based on standards in the thread.xlsx in Design Data. Each table is standard specific and there is no dual unit.
Many thanks!
Software Test Engineer
