Adding drawing user parameters to title block
jltw7PSW2
Message 1 of 10
jltw7PSW2
I am in the process of creating a new title block, so far the plan is to add custom iProperties to the drawing template so we can make a form to edit stuff like: Parts location on machine, which machine, material certificate and more "custom values" that varies from part to part.
But in this case I was hoping to add which machine the part belongs to as a dropdown in the from, I have managed this with a multi-value user parameter in the drawing template, however I cant figure out if it is possible to add this value to my title block?
Is there a way to do this?
Thanks!
Replies (9)
Message 2 of 10
admaiora
Something like that?
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Message 3 of 10
jltw7PSW2
Well almost, I would like it to be a dropdown in the form to choose from, almost as if you do a custom iProperty with a "Yes or No" type data, it will then be a dropdown in the form, but I need custom values in the dropdown, not yes or no.
Message 4 of 10
admaiora
You have to do that with user params, you can't do a multivalue custom iprops, or you can do that with iLogic code (that change on the way your custom iprop)
Admaiora
Message 5 of 10
jltw7PSW2
Yes, I am aware that it needs to be done by user params, that is the title of my post.
My issue is I dont know how to display a user param in the title block
Message 6 of 10
admaiora
You have to do that, linking param and ipros, with iLogic
Admaiora
Message 7 of 10
jltw7PSW2
Okay, and do you know how one would do that?
Message 8 of 10
admaiora
iProperties.Value("Custom", "MYCUSTOM")=MYPARAM
 You will find atatched the file.
Here some info about iLogic
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-9372F2A9-377E-40AB-92AA-5FC371BACF8C
Admaiora
Message 9 of 10
jltw7PSW2
This is exactly what i needed, thank you very much!
Message 10 of 10
admaiora
You are welcome
Admaiora
