Adding a coating to an existing structure
Hello everyone,
I am a new user of Autodesk Inventor and I am looking a way to add a layer of another material to an existing surface structure that is not just a plane layer but acts like a coating.
I hope someone can help.
Thank you in advance.
I think this is a very difficult job to model an extra layer. Why not just comment on the drawing?
marius.gildehaus
Hello @Anonymous !
I see that you are visiting as a new member to the Inventor Forum. Welcome to the Autodesk Community!
From your name, I would guess you are german, there is also a german Forum here.
This video from @Neil_Cross shows a good workflow to work with coatings, especially regarding the weight of paint for example.
But also @Anonymous is right, that sometimes it's easier to just write it on the drawing, depending on what you are actually trying to achieve.
Hope this helps!
Marius Gildehaus
Technical Sales Specialist
I'm a fan of his youtube channel, but didn't see this one before. Still a lot of work though 🙂
JDMather
I think you might have been misled by the previous responses.
AFAIK what you want to do is relatively easy to do and I have been doing exactly that for years.
Can you Attach a file(s) here that  you would like to add physical coating?
Thank you for your response. Unfortunately I cannot post the file since it's confidential material. Could you describe a simple way to add a coating?
JDMather
Standard practice is to make up a dummy file that exhibits characteristics similar to your proprietary data.
That is what I would have to do to fulfill your latest request, but I would be purely guessing about your true Design Intent.
Three typical examples that I have used:
1. Physical coating of paint to get accurate weight and volume of paint used.
2. Physical coating of Teflon on metal baking pan.
3. Overmolding of plastic coating over another substrate.
