Add unique text to elements of a rectangular pattern.
markbUA99P
markbUA99P
I wish to create a pattern of nameplates and be able to pit unique text on each without having to create a sketch for each. Parameters seems to be indicated but I can't figure it out.  (I'm a self-taught relatively new user.)  I've watched this quick tip a number of times but apparently I'm missing something.
pball
I had something similar with engraving a ruler on a part before. Short answer is there isn't a simple way to have a "pattern" of different text. It is possible to use iLogic scripting to auto generate textboxes. Below is a link to a thread where I shared my ruler Inventor file with the iLogic script in it. That script would need to edited to suit your needs for the pattern and what text it would add.
https://forums.autodesk.com/t5/inventor-forum/sequential-numbering-on-sketch-for-embossing/m-p/13604...
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Userscript to edit forum links to jump to first unread post
Jump To First Post Userscript
