Sequential Numbering on sketch for Embossing
Fazlur_Rahaman
Fazlur_Rahaman
Is there a way to add sequential number on part sketch without manually entering each number on TEXT?
I am modeling a scale (ruler with CM/Inches) mark.
pball
I can't find the original thread on this topic. But I have a copy of a ruler that has iLogic in it to auto add numbers. I haven't looked at in a few years, so I'd have to brush up on how it works if you need help understanding it. Hope it helps.
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Userscript to edit forum links to jump to first unread post
Jump To First Post Userscript
johnsonshiue
Hi! I don't think there is an out-of-the-box solution. More than likely, you will need a iLogic rule to automate the manual steps.
Many thanks!
Software Test Engineer
