Add a broken leader to the origin text of an ordinate set - Inventor Professional 2025
stagiaire8YW5B
New Member New Member
stagiaire8YW5B
New Member
New Member
I want to add a broken leader to the "0" of an ordinate set bot I can't find how to do it.
I need to move it to make some space for the other members of the set (see the attached screenshot).
Does anyone know how to do it?
If this is not a feature of Inventor, I strongly suggest it to be added. Especially since both Solidworks and Solid Edges have that feature.
@stagiaire8YW5B Your post title was modified to add the product name and version and to increase findability - CGBenner
CGBenner
@stagiaire8YW5B
Welcome to the Community!  I've moved your post here to the Inventor forum for better visibility.  Can you tell us what version of Inventor you are working with?
Chris Benner
stagiaire8YW5B
New Member
New Member
Yes, I'm currently on Autodesk Inventor Professional 2025
SBix26
It's a workaround, but here is the technique:
  1. Establish the dimension origin for the view by using the Ordinate Dimension tool (not Ordinate Dimension Set), but after placing the origin indicator exit the tool
  2. Create your ordinate dimension set, starting with a location where the leader can be or must be straight (the origin of the set cannot be jogged/offset/broken)
  3. While in the Ordinate Dimension Set tool, right click and select Options > Use Origin Indicator (this can also be done after exiting the tool); this sets 0 to the location of the view origin you established in step 1
  4. Move jogged/offset/broken leaders as you wish, with the exception of the first one you placed which cannot be broken
  5. If you want to change which member is the "straight one", right click on it and choose Make Origin; this will not make it the view origin (0), but will make it, in effect, the first member placed
Sam B
Inventor Pro 2026.1 | Windows 11 Home 24H2
CGBenner
@stagiaire8YW5B
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
