ddpont i have to say that you are a legend. i have not seen that setting before, or seen anyone else refer to it until now.
in my case, i had made a few copies of one large frame weldment, that resided within other general assembly files. the first weldment was adaptive & dozens of constraints were depending on this adaptivity, so all copies i made were by default tagged as adaptive within the document settings as you say.
i was able to untag all frame assemblies as "Adaptively Used in Assembly". then go to each of their new (parent) general assembly files and make them adaptive within each appropriate parent.
i think you may have saved me about a days or reconstraining!
thanks again, & keep up the good work.
@Mark_Wigan wrote:ddpont i have to say that you are a legend. i have not seen that setting before, or seen anyone else refer to it until now.
thanks Igor,
i did see that it was answered and that it was a long time ago.
i still wanted to say thanks to dd... if he is still around 😉
Alas, a lot of good people left Autodesk Inventor discussion group and have now moved to Mcad forum run by Sean Dotson...
