Inventor Forum
A-Side Compute Error - Sheet Metal Part
7 REPLIES 7
Message 1 of 8
3994 Views, 7 Replies
Inventor tells me to fix the A-Side Definition, but I don't find a way to do it. Here's a screenshot of the problem:
You are my Inventor training. Thank you for that.
7 REPLIES 7
Message 2 of 8
JDMather
JDMather
Attach your *.ipt file here and end all doubt.
Why did you use an Extrude feature for a simple sheet metal part?
From the image, something doesn't look right with the Cut.
Message 3 of 8
-niels-
-niels-
You cannot "fix" the A-side definition as long as there's a flat-pattern present.
If you delete the flat-pattern, you can delete or redefine the A-side.
Also, see JDMather's remarks about the extrude feature...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Niels van der Veer
The Netherlands
Message 4 of 8
JDMather
JDMather
Did you figure this out?
Message 5 of 8
in reply to: JDMather
I tried it with a Face feature instead of Extrude. That fixed it.
I must remember to use Face for sheet metal parts.
Message 6 of 8
JDMather
JDMather
There is no reason you cannot use Extrude rather than Face, but you must use it correctly.
Message 7 of 8
Just as an additional....I was having the same error message so I took Niels advice and deleted the flat pattern.
Turns out I'd added a flange when a flat pattern had already been created, so once FP was deleted the problem resolved itself.
Message 8 of 8
in reply to: -niels-
Ty man, this was annoying problem and it was so easy to fix it.
