Inventor Forum
A Pipe Fitting Modelling Challenge that's got my stumped!
5 REPLIES 5
FProcp
384 Views, 5 Replies
I have a straight 10" pipe with two elbows going into it.
Please see the attached pdf.
I don't know how to cut the holes the two elbows would make in the straight pipe.
I have tried subtracting solids using the Copy Object and then the Sculpt command.
But, I can't get it to work!
I've already created the elbows cut to how I need. I just need to make the holes in the straight pipe 😫
Franco
GMT +08:00
5 REPLIES 5
mpatchus
in reply to: FProcp
Possibly try sweeping the pipe ID along the Elbow Centerline?
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
FProcp
in reply to: FProcp
Here is an attachment of my work.
Franco
GMT +08:00
FProcp
in reply to: FProcp
This is difficult because of the obscure angles the elbows are coming in at.
Please JD
Franco
GMT +08:00
johnsonshiue
in reply to: FProcp
Hi Frank,
This can be done by using Surface Modeling workflows. First, edit the elbow and move EOP right below the Sweep feature. Use Thicken/Offset to create a surface based on the inner face of the elbow. Then move EOP down. Repeat the same steps for the other elbow.
Now, edit the pipe and use Copy Objects to link the two offset surfaces. Lastly, use Sculpt or Split command and select the offset surfaces to cut the pipe. Please see attached file.
Many thanks!
Software Test Engineer
FProcp
in reply to: FProcp
Thank you, I've done it 😃
Franco
GMT +08:00
