- Mute
- Permalink
- Report
Hi All,
I am using 2025 Inventor. I have a strange request from client and this is for modelling point of view as they want to put this model for their online catalogue. In reality, side walls will be welded and rounded off. But for modelling purpose, it has to be in 1 piece.
I have done derived part but not sure we can get this in 1 profile (single plate)? Can any1 give it a shot. Plate thickness is 1.5mm and overall dim is 400Lx400Wx300H. I have done this in 2 sections or 4 sections but not in 1 go.
Other alternate option is, to draw sharp edge rect with offset of 1.5mm and apply flange from 4 corners at the bottom and later on do fillet option for 4 wall corners. But then you will have gap in 4 corners. Not sure which is better way to do this.
So main question is, can we do sheet metal of 1.5mm wrapped around this skeleton or derived part in single go?
Thanks in advance.
Yash
