[Inventor] Sweep cut not working
ksgmsjkjw
ksgmsjkjw
Hello. (Using Inventor Professional 2026)
I made a blue triangle profile and path like above to do sweep cut.
Somehow, I can't choose a path from the option when I try to do sweep.
Is this impossible situation to do sweep cut? If not, what would be the problem of my path for sweep cut?
SBix26
I can't tell from the images what the problem might be.  Can you post the file here, and let us know what version of Inventor you're using?
Sam B
Inventor Pro 2026.1 | Windows 11 Home 24H2
ksgmsjkjw
Hello. I'm using Inveontor Professional 2026 version and I've just uploaded my file to the original question.
Thank you.
kacper.suchomski
Hi
Your path is freeform – the sketch is not fully constrained.
Don't finish working on the sketch until the pin icon appears in your browser.
Tweak the sketch to use it as a path.
Kacper Suchomski
ksgmsjkjw
Thank you!
I constrained every sketch in the file like you said. It worked perfectly.
There is another small question though, when I constrained the sketch, I can tell it's constrained by it's color but the model tree says otherwise. Is this some kind of a glitch or something? (from my settings, fully constrained sketch is shown in purple)
kacper.suchomski
@ksgmsjkjw wrote:
Thank you!
If Inventor says that a sketch is not fully constrained, it is. You can check this in two places: the browser icon and the status bar.
As Samuel mentioned
Kacper Suchomski
