& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
I'm trying to find a screw,
5/32" x 3/4" Brass screw (doesn't actually have to be brass)
but I haven't a clue where to find it. Or would I need to make a custom one? I want it to look like the one I have attached.
That would be in machine screws.
You can try clicking the filter and selecting the standard you want.
Use the search box.
Or if it doesn't exist you can make your own.
Find the family that is closest and then use this method to add it.
https://forums.autodesk.com/t5/inventor-forum/add-new-beam-in-frame-generate/td-p/10632814
If you need brass, you can copy the family using material advisor at the top of the content center window and choose brass.
There is a huge amount of screws depending on each application, supplier or country. Usually, you can find the exact name & specification (Including which standard is : ANSI, ISO / DIN ...) on the screw box.
You can pick the most similar from content center & modify it without need to create it from scratch.
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
5/32" (.156 in) is not a standard screw size in any system that I know of. However, it is very close to a metric M4 size (.157 in), and just a bit smaller than a #8 (.164 in).
The thread pitch is important— a #8 machine screw will likely have 32 threads per inch (thread pitch = .031 in = 0.79 mm), while a M4 machine screw will probably have a thread pitch of 0.70 mm = .028 in (~36.3 threads/inch). While these numbers don't look like much difference, you will not be able to thread a machine screw very far into a nut or thread of a different thread system before it locks up.
If you really don't know whether it's inch or metric, then find a nut of a known size (#8 or M4) and see if it threads in easily. Now you know...
Sam B
Inventor Pro 2022.1.1 | Windows 10 Home 20H2
LinkedIn
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
