3rd Party app wont run, log-in as different user and it runs
karthur1
Mentor Mentor
Message 1 of 10
karthur1
When I try to start my 3rd party app, it does nothing.  I log back into Windows using a different user account and then the app will start and run just fine.
I uninstall/reinstall Inventor, but the problem persists.  I am sure its something to do with the Windows profile, just don't know where to start to fix it.
Any ideas what to try/do to resolve it?
Windows 10
INV Pro R2018.2.3
Vault Pro 2018
Kirk A.
Replies (9)
Message 2 of 10
MSD_takaseh
Hello karthur1,
I'm afraid but not sure why 3rd Party app won't run.
Please try followings.
1. Disable an monitoring application like unti-virus.
2. Remove a content of %temp% folder.
3. Set User Account Control of Windows to "Never Notify". (Reboot the machine)
4. Run the Inventor as Administrator with RMB.
Also did you use uninstall tool when reinstall Inventor? If no, please reinstall again with that.
Hitoshi Takase
Message 3 of 10
johnsonshiue
Hi Kirk,
Is this an Add-In? If yes, please go to Tools -> Add-Ins -> find the add-in and uncheck "Block."
Many thanks!
Software Test Engineer
Message 4 of 10
Xun.Zhang
Hello Kirk,
How about run Inventor as administrator?
Thanks!
Xun
Message 5 of 10
karthur1
Thanks for the suggestions.  This is an add-in and it does show in my Add-ins Manager and its not blocked there.  There is an icon for the add-in on the ribbon, but with the one account, it does nothing when I click the icon.
I did use the Autodesk Uninstall tool to remove all parts of Inventor.
I have already tried running Inventor "As Administrator" and the problem still persists.  I will try cleaning out the %temp% folder tomorrow and disabling the anti-virus software our IT has going.  The anti-virus we have is called WebRoot.  I will disable it and try running "As Administrator" and see what happens.
Message 6 of 10
karthur1
Tried all the things mentioned above, but problem still persists.
Message 7 of 10
johnsonshiue
Hi Kirk,
Have you try re-registering Inventor? Start up Windows command line (cmd) and go to Inventor \Bin\ folder and type in "Inventor.exe /install" and hit <Enter>.
Many thanks!
Message 8 of 10
DannyHubbard
My first thought would be permissions issues, and disabling UAC like Xun mentioned. Another thing to check is as the user that can't run the addin. Go to the folder "C:\Users\<username>\AppData\Roaming\Autodesk\Inventor 2018\Addins" look for an addin file for you Addin and rename it or delete it. Then start Inventor again and try your adding.
Beyond that I would think the Addin is trying to read or write to a location it doesn't have permissions to as this user like under "C:\Program Files" or in the HKEY_LocalMachine branch of the registry.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 9 of 10
MechMachineMan
Ensure the windows date/time format is consistent between the 2 user accounts.
Also, check to make sure the windows "Show/Hide Known File Extensions" settings is the same between the 2 accounts.
If the program was done super thoroughly, they may have forgotten about these things.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 10 of 10
karthur1
The particular add-in created a .config file when it is ran to store some of the information.  I copied the .config from the working user profile to the non-working users profile and it worked then.
It probably was some sort of permissions issue where windows was not allowing the addin to write to the directory, but I just never could find the actual smoking gun.
Finally got it to work though by doing that.
