3Dconnexion problems
Message 1 of 29
Hi All,
Is anyone using the latest software download from 3DCONNEXION with a Space Navigator?
I just downloaded it and installed but can't get Inventor 2017 to recognise it!
Anyone know what to do?
Rob
Replies (28)
Message 2 of 29
JDMather
Well, at the risk of offending I have to ask, "Did you reboot your computer after installing the new driver?"
Check your Add-ins Manager, is it Loaded?
Message 3 of 29
Yep, rebooted and checked the add-in and all is well. I'm assuming that the 3DConnexion software should pick up on Inventor if it's loaded, but it doesn't. Seems to default to this:-
Any ideas?
Rob
Message 4 of 29
JDMather
Oh man, I was regretting installing this new driver for a moment.
I think there is a bug in it.
With Inventor file open, open the 3D Connexion control panel.
On my machine it shows the wrong program (just as you show).
Restore Down Inventor and the 3D Connexion control panel changes to Inventor focus.
All is well.
I tried in SolidWorks, and Fusion 360 as well.  Same behavior.
If you have two monitors and drag the 3D Connexion control panel onto second monitor - you can select program to change settings on the first monitor without doing the Restore Down.
Message 5 of 29
The 3Dconnexion driver will recognize the program that is currently selected, not just running.  If you click on the Inventor window, the driver will then display that.
Message 6 of 29
JDMather
@Anonymous wrote:
... If you click on the Inventor window, the driver will then display that.
The problem is that when I click on Inventor - the 3D Connexion control panel goes behind the Inventor screen.
It used to stay on top with older driver versions.
This isn't my first rodeo.
Message 7 of 29
Shrink the Inventor window so they are both visible, cowboy.
Message 8 of 29
JDMather
@Anonymous wrote:
Shrink the Inventor window so they are both visible.
Which is what I already wrote.
I guess I could have written Minimize instead.
In any case this is an issue that never occurred in the past, and now 3 work-arounds have been given.
Restore Down the Inventor window (this has the effect of making Inventor the active component in the panel).
Minimize the Inventor window (this has the effect of making Inventor the active component in the panel).
Drag the 3D Connexion control panel to second monitor.
Message 9 of 29
There is also a button on the mouse that will pop up the settings in front
of Inventor. It's on the left side of my space mouse.
Message 10 of 29
Hi Guys,
Thanks for all the feedback, over come the problem now. Would be nice to have the option to select which program you wanted to make adjustments on, as for me, it wasn't clear that it was the active program it would work on and didn't help when it disappeared behind Inventor. Definitely helps using the dual screens!
Thanks for all the help again.
Rob
Message 11 of 29
danijel.radenkovic
Hello JD,
I have a problem with my 3D SpaceNavigator.
This morning when I have started Inventor, I realized that my 3D model rotates very slow. I have tried to uninstal 3D connexion driver and I have installed it again but still the same problem. Moving, rotating model is so slow.
I have checked that I have installed final drivers for 3D connexion and also final drivers for my NVIDIA M5000M Quadro Notebook Drivers:
NVIDIA: 375.63
3D CONNEXION: 3DxWare64_v10-4-7_r2465
My computer is on Windows 10x64 Pro and Inventor 2017.3 build 233
Video which describes a problem is in attachment.
Any help please???
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
Message 12 of 29
-niels-
Just curious, but what are your speed settings?
If you right-click on the tray icon and select "calibrate" does that improve anything?
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 13 of 29
danijel.radenkovic
Hi Niels,
Here is a screenshot of my settings. I always use the default settings. I have just tried calibration and still the same problem. Nothing has changed.
Message 14 of 29
danijel.radenkovic
Here is something interesting that I realized. If I try to test via Cube C3D Demo test from connexion folder it works pretty good, but if I try it in Inventor, it is unbelievably slow.
Message 15 of 29
-niels-
Your screenshot shows the speed settings for Firefox, though if you always use the default i don't think the Inventor settings will be different...
Does increasing the (overall) speed on the first panel do anything at all in Inventor?
I'm on a driver a release earlier then you, v10.4.6, and IV 2016.
Maybe they changed things a bit, but if you can correct it by setting the speed higher then that should solve it.
(or was it faster before?)
Niels van der Veer
The Netherlands
Message 16 of 29
danijel.radenkovic
Hi Niels,
Sorry for the image above, here is a screenshot for Inventor settings.
I have recorded video of changing speed via slider but the result is the same.
Message 17 of 29
-niels-
Indeed, seems like it's only a little faster... not as much as i'd expect when changing the speed all the way up.
Is this only with this particular model, or with everything in Inventor?
I don't really know what it could be, i checked the release notes for the 3dconnexion driver and there isn't anything inventor related that got changed.
Did it move properly before? what changed since then?
It could even be windows updates or other background processes, when did you install the R3 update for inventor?
Calibrating didn't do anything, but maybe unplugging the device could help?
I'm just typing out my thoughts here now, you've got a strange problem...
Niels van der Veer
The Netherlands
Message 18 of 29
danijel.radenkovic
Yes you are right, it is a little bit faster but it worked perfectly until this morning. It is the same case with assemblies, not just with parts.
As I remember, nothing has changed since yesterday. Inventor R3 has been updated ten days ago.
I have tried with unplug/plug the device but still the same. I have plugged device on another machine of my colleague and it works perfect.
There is something happened with my Inventor, I can't realize what.
Danijel
Message 19 of 29
JDMather
@danijel.radenkovic wrote:
...I have a problem with my 3D SpaceNavigator.
I didn't watch the video(s), but try this.
Unplug the Navigator.
Hold down both buttons while you plug it back in.
Keep holding both buttons for about 15 seconds.
Now try it again.
Message 20 of 29
danijel.radenkovic
I have just tried what you suggested but still nothing happened better.
