- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to create a 3D model of a tunnel that curves 180 degrees and also rises about 10 metres. I have created a 3D sketch of the centre line of the tunnel and a 2D sketch of the profile of the tunnel. I then created a sweep to build the solid tunnel.
However, The solid that is created has "rotated" while it travels along the 3D centre line. This results in the face at one end of the tunnel being "tilted" (I want both ends of the tunnel to be parallel to the x-axis)
I have tried using the TWIST option in the sweep command box but it always comes up with an error. I have also tried using lofts, however the only seem to work on the same plane (Because there is a difference in x,y and z the lofts don't work).
Is there anything I can do?
I have attached the part file for the section of the tunnel that I am having trouble with.
Thank you in advance.
