Inventor Forum
3D sketch on a drawing
8 REPLIES 8
Message 1 of 9
TONELLAL
1492 Views, 8 Replies
TONELLAL
How can I displaya 3D sketch on a drawing, but not above the view ?
The 3D model : the array is a 3d sketch
The obtained drawing : the sketch is always above the view, like if drawn on the sheet :
The drawing needed :
Any ideas welcome, if needed I'll create an Idea
8 REPLIES 8
Message 2 of 9
K_Baker_89
in reply to: TONELLAL
K_Baker_89
Could you attach the part in here please?
Cheers,
Kurt
Cheers,
Kurt
Message 3 of 9
TONELLAL
in reply to: K_Baker_89
TONELLAL
Here's the model
Here's the model
Message 4 of 9
K_Baker_89
K_Baker_89
Thanks for sharing the file.
How have you managed to get the sketches showing on your drawing? "Get model sketches" only works (as far as I know) on part drawings and not on assembly drawings.
When I project views, the plate is positioned correctly, but I'm unable to get the grid sketch to show...
Message 5 of 9
SBix26
SBix26
I couldn't find any way to achieve what you want, either in 2016 (the version of the files you posted) or in 2018.
Sam B
Inventor Pro 2018.2.3 | Windows 7 SP1
LinkedIn
Sam B
LinkedIn
Message 6 of 9
johnsonshiue
johnsonshiue
Hi! I can reproduce the behavior. Indeed, model 2D/3D sketch can be retrieved in the drawing view. But, it does act like an overlay on top of a model view. Model sketch geometry does not participate in hidden line compute. As a result, it appears on top of the view.
Many thanks!
Software Test Engineer
Many thanks!
Message 7 of 9
Curtis_Waguespack
Hi @TONELLAL,
Could you create the part called Pièce1 as a single 60x65 rectangle and then use the Rectangular pattern to create the larger grid, but do this as separate solid bodies?
I hope this helps.
Curtis
Hi @TONELLAL,
I hope this helps.
Curtis
Message 8 of 9
TONELLAL
An idea yes... but :
-this mean to create an assembly instead of a part
-more boring, the sketch need to be an array. On real models, I have nothing regular
In the same theme I can create split features, but in a split I can use only 1 line. In my sketch I have dozens...
Message 9 of 9
TONELLAL
TONELLAL
So, I note there is no solution to display a sketch on the 3D model and not directly on the sheet. This will be reported on Inventor Idea.
The easiest workaround I found is to create a "snake sketch" and use it to split the face : 2018-04-12_11h29_47.png
