3D PDF iLogic
3D PDF iLogic
3D PDF iLogic
I just finished migrating everything over to the 2017 version. I started playing with the 3D PDF function which I was very excited for and I see others are already experiencing problems so I bet my problems wont get resolved either but its worth a post!
Basically my problem is that I need my LOD's included in the pdf but this does not look possible. When i start the export, another window opens up of my assembly but with everything set to the Master design view. This is basically useless to me because I have many iLogic rules and parts are supposed to be suppressed to remain accurate.
Also, up until this point in my limited Inventor experience, I have only used view reps and LODs to create single component drawings from a top level assembly, so i dont really know why else I would want to include all of these other view reps in the 3d pdf when they are all set to "master". They all look the same.
Any feedback is appreciated!
Sandro
swalton
Are you using View Reps and LODs to create assembly variations?
iAssemblies are the as-designed tool for that workflow.  I'm not sure how well they play with iLogic though. You might have better luck with your 3d pdfs using iAssembly members.
I wonder if the issue is related to saving position reps.  See http://forums.autodesk.com/t5/inventor-ideastation/assembly-positional-representations-saving-in-act...
Why are you using view reps and LODs to place views of single parts in a drawing?  Why not just place a view of the part file?
Steve Walton
Inventor 2025
Vault Professional 2025
andrew_faix
Hi Sandro, thanks for posting.
As you have discovered, LODs are not supported as part of 3D PDF publish.  Please try this solution:  right click on your LOD in the browser and choose "Copy to view rep."  This creates a coresponding design view rep.  Then you can use these new design view reps to control your published output.
The reason design views are leveraged as part of 3D PDF publishing is that they control much more than componet visabilitly.  Design views also store sectioning, camera position and later they will control 3D annotation visability.   LODs, however, only control componet suppression status.  LODs were designed and implemented as a tool for memory management and not necessarliy for controling componet visability.
Hope that helps.  Please report back your thoughts and findings.
-Andrew Faix
Principal UX Designer
-Andrew Faix
Principal Experience Designer
Autodesk, INC
thanks for responding guys. It seems the origin of my issues is my lack of understanding of View Reps and LODs. I do not fully understand yet but I think I have a better idea.
Swalton thanks for your response but I have no experience with iAssemblies and I have been told to stay far away from them especially with the use of iLogic.
Andrew, I tried what you mentioned and it worked better for me. It still took some tinkering because of my lack of understanding of what the difference is but it appears I got the pdf to look like what I wanted.
So the only issue with the pdf that i dont believe is caused by myself is very odd.
one of my View reps had a portion of it basically cut out. when i spun around my model, certain camera angles would allow me to see the whole component while others would show a portion cut out. I simply re-made the pdf and i had the same problem but on a difference view rep. I Dont know if this is the solution but what worked for me was going into that view rep, clicking the home button, and then zooming out one scroll of the mouse, then save.
thats all for now!
