3D PDF Export - In Acrobat not visible
premysl.misun
Message 1 of 22
premysl.misun
I have to export my assembly file of machine to 3D pdf for my customer. It seems that everything is OK, but if I open pdf in old or new Acrobat Reader (version 17.012.20098) all parts are not visible (same problem has my customer). In tree in Acrobat are all of them but if I try right click and visible all parts it is the same. I have this problem for long time, for some very simples assembly it is working.
I try this on my PC and notebook, problem is the same. I have updated Inventor 2018.1.1 (Build 171). On PC Windows 7, on notebook Windows 10. In Inventor 2017 was all ok.
Thank you very much for your help.
Premek
Replies (21)
Message 21 of 22
deividas
Thank you for your help
not as it should work. I can't accept the same wood look styles that are selected for ipart, it works if I change to a different one, but it looks wrong. because the wood texture lost in 3D PDF becomes a solid color (brown)
Message 22 of 22
johnsonshiue
Hi! Either this is a design view/appearance style corruption bug or the styles were not available at assembly level. If possible, please share the iam and ipt file with me directly johnson.shiue@autodesk.com.
Many thanks!
Software Test Engineer
