I'm trying to draw 3d line on cylindrical surface which can be easily made by a chamfer tool (see below - dark green line).
Distance between cutting line and the dark green line is the same in each point.
The problem is that I don't want to make a chamfer. I only need a 3d sketch or a surface tangential to the bigger pipe.
I also tried to make it by "wrap to surface" but the outcome isn't satisfying:
Blue line is made by a chamfer tool and yellow by curve to surface projection.
Any ideas how to make the blue line as a 3d sketch without chamfering ?
Solved by Curtis_Waguespack. Go to Solution.
Can you attach your *.ipt file here?
Hi fdcsaz,
One method would be to create the Chamfer, project it into a 3D Sketch, then use the Delete Face tool with the Heal option.
I hope this helps.
Curtis
Please see attached files to see if this is what you are looking for...
Inv. 2017
Thank you Curtis_Wagues... Your method is ok, but requires few additional features especialy when I have main pipe and junction pipe as a separate bodies (I have to do this on surface objects).
Thank you blandb, but I still don't have Inventor 2016 so I am not able to open your files. I will check them soon.
I think that there should be some feature implemented in future version of inventor which will help with such an issue. Some kind of offset on 3d surface.
