Hi guys,
Does any of you have large screen (28") and at the same time problem with your ADSK CAD like Inventor or ACAD? Our client does. And I can't find any settings that would fix that, ADSK Case told us that there is also none... But... I kind of dont think that our client is like the only one with large screen and using CAD at the same time. That doesn't sound possible.
I attached few images of broken CAD (or barely usable with screen large like this) and on the other hand OK images of other Win applications.
Any ideas anyone?
Thx
Some screens in attachments, rest is here on DropBox: https://www.dropbox.com/sh/76inf8zugu2wtmv/AAAvlb2bXlJaOByoqoVRi9VJa?dl=0
Solved by blair. Go to Solution.
OS? Graphics card model and driver version?
Are you up to date on INventor 2015? Sp2 with Update 2?
Mark Lancaster
& Autodesk Services MarketPlace Provider
I use a HP30z 30" at work and don't have any problems. I think you might have a problem when you get into hi-res monitors. A few problems have cropped up with 3000dpi monitors. Some of the windows within Inventor are Pixel driven and not scaled as a percentage of the primary window size. This causes some of the windows to become rather small with hi-res monitors.
Hi, thx for info, DPI really could be the case here. Could you post here a screnshot of your CAD (Inventor?) so I could see how it looks on your big screen?
Thank you very much
What happens when the display settings are increased? If you go to Control Panel\Appearance and Personalization\Display there should eb an option to change diplay settings from "Smaller" to "Larger"
This is with my 28" ViewSonic on my home office.
thx a lot for your help. It really will be problem with DPI.
The screen that has the problem is: AOC U2868 with max resolution 3840x2160@60hz
