2022.5 error while opening assembly "File <filename> version <number> could not be located at the given path nor at ....
- Mute
- Permalink
- Report
I guess this is the place to notify y'all of a reappearing bug that was noticed in inventor 2022 and fixed in version 2022.1/2023?
Issue almost exactly as described here: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/File-path-version-...
reappearing in Inventor Professional 2022.5 (issue not present in previous versions up to 2022.4)
Issue:
error while opening (sub) assembly/parts :
"File <filename> version <version number> could not be located at the given path nor at <Filepath>"
-the file cannot be opened or edited, but subassemblies don't necessarily have the same issue and can be opened and edited
-the file is present at the given path, not checked out, not read only
-sometimes closing and reopening the file fixes the issue, but usually deleting and redownloading the file from vault is the only (known) fix
