Are there any major differences between Inventor 2022 and 2025
mads_ejlersen
Observer Observer
mads_ejlersen
Observer
Observer
I have downloaded the 2025 version.
I will have training in Inventor in two weeks, where the instructor says it is a good idea to use the 2022, since he does and it will be easier to support me.
Are there any major differences or can i use the newer version?
kacper.suchomski
Hi
There are some new features; the appearance of some tool dialogs/panels has changed.
Check out what's new here:
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-79BEECAC-18E6-478A-8406-1DD581F620D6
Kacper Suchomski
James_Willo
There has been hundreds of enhancements in that time, but I don't think we have removed anything since 2022 so everything he teaches should be the same. The only difference might be that they look different. For instance, sheet metal now has a modernised interface, but the basic techniques should be the same.
Vs
James W
Inventor UX Designer
jnowel
In terms of support, your instructor can't open the 2025 files in his INV 2022.
If you encounter issues with 2025, they may not be able to troubleshoot & replicate the issues on their end.
If I were you, I'll stick with 2022 for now during class if your instructor is keen on using that version.
johnsonshiue
Hi! Here are the enhancements implemented in 2023, 2024, and 2025.
Inventor 2023
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-CCB31B06-3153-4B0F-BB20-2152D6F2B1FC
Inventor 2024
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-A542F6DE-7FFC-4697-9565-0CB04CB8510B
Inventor 2025
Many thanks!
Software Test Engineer
