Usually by now there have been several "whats new" features about up-coming releases, but I have seen nothing at all related to Inventor 2019. Does anyone know what is happening and is there in fact going to be a 2019 release.
Solved by TheCADWhisperer. Go to Solution.
Solved by mcgyvr. Go to Solution.
@Anonymous
Is this what you're looking for: https://forums.autodesk.com/t5/inventor-forum/its-here-inventor-2019-what-s-new/td-p/7883776
Mark Lancaster
& Autodesk Services MarketPlace Provider
I just found the Autodesk Virtual Academy, What's New Series. Here's the link for it http://hs.ketiv.com/whats-new-vault-inventor-autocad-2019
Hi Jim,
so Inventor 2019 is still not released, correct?
normally all these what's new documents are coming after released date... not after...
See you in a few months in vegas.
radu
Inventor 2019 standalone was released on March 26th. Customer fulfillment are underway.
If however, you have Inventor through a suite/collection then they are planned for release mid-April. Student license fulfillments generally occur later.
The date also varies depending on your geo location & availability of language packs, etc.
Chris
