2019 Measure Loop
2019 Measure Loop
Robert.Reid
Message 1 of 27
2019 Measure Loop
Robert.Reid
Did Autodesk drop the ball on the measure tool again?
How do I find the Length of the Cut Extrude inside the rectangle?
WITHOUT HAVING TO DO MATH!
Replies (26)
Message 2 of 27
Cadmanto
In the measure tool select below and pick the face.  Don't know about 2019, but it is in 2018.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 27
johnsonshiue
Hi! The ability to measure a loop is still there. You just need to right-click on an edge -> Select Other -> select Loop.
Many thanks!
Software Test Engineer
Message 4 of 27
And how to get this measure on the 2D drawing?
Message 5 of 27
johnsonshiue
Hi! Measure tool was removed from 2D drawing starting from Inventor 2018. The reason why it was removed is because of ambiguity of the measurement. Measure tool by itself is for 3D. Within the drawing environment, the view geometry is actually like a camera view of the 3D model. When you measure from one point to another, resultant measurement can be in 3D. If you are looking for the 2D measurement, you can create drawing dimensions so that they are measured in 2D space.
Many thanks!
Message 6 of 27
IgorMir
Hi Johnson;
I am with Robert on that one. How can I document the length of the loop? It doesn't matter what for. Say, for simplicity - I just need it. Apart from creating a bunch of dimensions in the sketch, add them all up and create a User Parameter which reflects the total length - I couldn't think of any other, simpler solution. Or is there one?
Cheers,
Igor.
Many thanks!
Web: www.meqc.com.au
Message 7 of 27
GeorgK
@johnsonshiue Hi Johnson,
it would be great to have it again. It takes time to switch between the drawing and the 3d model.
Georg
Message 8 of 27
Hi thanks for replays.
It was a funktion like this (in another 3D program) Smiley LOL
https://www.youtube.com/watch?v=3WXt2DM2Ogs
Message 9 of 27
mpatchus
@Robert.Reid @IgorMir @Anonymous
I've used this method in the past.
Measure the internal loop in your part and copy that measurement to a User Parameter in the part (something like INT_LOOP), then use that parameter on your drawing.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 10 of 27
IgorMir
Hello Mike;
Could you please tell us what will happen to that User Parameter once the model is edited and the length of the loop is changed?
Cheers,
Igor.
Message 11 of 27
IgorMir
That's is done very elegantly indeed.
Cheers,
Igor.
Message 12 of 27
mpatchus
@IgorMir
If you alter the geometry, you do have to remember to remeasure and paste the dimesion into the parameter.
I don't think there is any way to link it at this point.
Inventor 2025 Beta
Message 13 of 27
IgorMir
Thanks, Mike;
Unfortunately - from the beginning  the suggestion of yours didn't have much of a value. Since it leaves a great deal of opportunity to create a user error. And that's what I was trying to point out to you in my previous post.
Best Regards,
Igor.
@mpatchus wrote:
@IgorMir
Message 14 of 27
Ksmedley
This was a tricky one to find...
Kevin J. Smedley
Message 15 of 27
inv-design
Observer
Observer
So tricky, in fact... that I still can't find it.  In v.2018, I could right-click and select Loop from the pop-up menu.  It doesn't work in v.2019.
I use this all the time when working with roller chain and sprockets.  My sketch in the chain model consists of two arcs (drawn at the pitch diameters of the two sprockets) and two tangent lines connecting them.  The length of these two arcs plus the tangent lines are my chain length, which obviously needs to be a number equally divisible by the pitch of the chain.  Then this loop is offset to the inside and outside to represent the height of the chain, and then this region is extruded to the chain width.
In the attached screenshot, you can see the menu that pops up when I right-click on the line.... no option to "Select Other."  What am I missing here?
Someone please, PLEASE explain how I can measure this loop.
Message 16 of 27
johnsonshiue
Hi! Did you happen to have the following registry key set?
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Inven...
Many thanks!
Message 17 of 27
Hi
Note to Autodesk -
Makes it possible to measure loop directly
And make it a part of dimensioning on loops. (as on the other 3D program) 🙂
Please.....
Message 18 of 27
Yashasvi23481
Hi Robert,
   For complicated profile like this, would not you create a dxf and send to cnc ? in that case, you don't need a details of the loop length. When you have complex profile plate like this, I usually prefer exporting face to dxf and on idw just give overall dimensions. I have not come across need to calculate such loop or cutout. Whether you have your own manufacturing unit with cnc or outsourcing to cut it elsewhere, dxf is usually created using export face as.
Its too much time consuming. Maybe I am going tangential but that will be my approach.
Yash
Message 19 of 27
johnsonshiue
Hi! Measure Loop should work. You simply need to right-click -> Select Other -> find the loop selection, when Measure tool is active.
Unfortunately, there is no loop dimension yet. I have heard about the request but it has not been implemented. Please feel free to report it as an idea on Inventor Ideas forum or vote for an existing one.
Many thanks!
Message 20 of 27
I do not see this as an improvement.  Autodesk loves 'fixing' what ain't broke.
