2016 to 2018 add audio to animation of assembly constraints
Is this possible?
JDMather
Depends on your end goal.
If you want clean image of assembly animation only - then you would need something like Techsmith Camtasia Studio to add the audio track to the video.
If you are OK with the Inventor interface in the video you could use Autodesk Screencast Recorder.
Thank you.
