JIC Thread
JIC Thread
matt_jlt
JIC Thread
matt_jlt
Does any one have any ideas on how to model a JIC Thread with inventor. I can model the physical geometry but not sure on how I should do the thread feature. If anyone else has done this can you please give me some pointers or any ideas would be helpful.
I think it may be a two part approach.
Step 1: Draw the thread flared end and the major diameter of the thread and do the undercut at the back.
Step 2: Create a custom thread feature and add it to the thread spreadsheet and add the feature to the thread face
Fitting information below
https://en.wikipedia.org/wiki/JIC_fitting
Thanks, Matt.
JIC use standard threads: UNF and UN.
Model the fitting and use thread feature.
Model the port and tap the hole.
You could create iFeature for the port.
matt_jlt
Thanks Frederic, you wouldn't happen to have a link to the port dimensions?
I can't seem to find any good detailed info on this online.
Looks like JIC has to fit into another fitting.  You'll need an adapter to fit it into another port: NPT, SAE, O-Ring Boss etc.
The wiki you linked has a link to Parker fittings.  You can see which one you can use.  I believe Parker and other has model for their fittings.
matt_jlt
Thanks again for your help, I'll just have to find the full dimensional standard for this standard and use that.
Thanks, Matt.
