Inventor Forum
2010 stability
8 REPLIES 8
Message 1 of 9
jon.myers
597 Views, 8 Replies
2010 stability
jon.myers
Has anyone else been dealing with a lot of crashes in 2010? We upgraded a few weeks ago and have had more than normal reports of crashes in our department. We have around 20 regular users. Unfortunetly we also upgraded a lot of the PCs at the same time so it is possible that may be the issue also. We are still using Windows XP pro 32 bit SP2. We've addressed the spaceball driver issue for the people that use those.
It is possible that some problems are caused by the fact that we are often working with complex parts and large assemblies of those parts so that many users spend a lot of time in the "yellow" and "red" zone of the resource meter. We have been unable to convince our IS department to install 64 bit OSs across the board but we have a couple of test machines with 64 bit XP and 6-8 GB of RAM.
Any thoughts?
-Jon
old machines:
Inventor 2010
Windows XP pro SP2
HP xw6200
4GB RAM
3GB switch enabled
3.2GHZ Xeon CPU
Nvidia Quadro 3450 using Direct3d w/ driver: 6.14.11.6996
new machines:
Inventor 2010
Windows XP pro SP2
HP xw 8600
8GB RAM (I know we can't use it, but we dream of 64 bit)
Nvidia GEForce GTX 280 using Direct3d
2010 stability
Any thoughts?
-Jon
old machines:
Inventor 2010
Windows XP pro SP2
HP xw6200
4GB RAM
3GB switch enabled
3.2GHZ Xeon CPU
new machines:
Inventor 2010
Windows XP pro SP2
HP xw 8600
8 REPLIES 8
Message 2 of 9
mcgyvr
in reply to: jon.myers
mcgyvr
Are you getting the CER (crash error report or whatever its called) screen after the crash? If so do you submit those or just ignor.. You really should submit everyone if you don't.
I was having crashes and it was a crash without the CER and it was 100% related to the 3d connection space navigator.. The latest driver has stopped those crashes completely.
Message 3 of 9
mcgyvr
mcgyvr
Also are you using the Ribbon UI? If so try switching back to classic UI (application options..colors tab) and see if that helps.
Message 4 of 9
dloganbill
dloganbill
I too am having stability issues. I just got a new Dell workstation:
Dell T5500
Quad Core E5520 2.26 GHz
6GB DDR3 ECC SDRAM 1066MHz
Quadro FX 4800 1.5GB
160GB SATA X 2 in RAID 0
Vista Business x64
I get both crashes with and without the error screen. I don't use the space pilot, so that isn't an issue.
______________________________________________________________
Autodesk Product Design Suite Ultimate 2018
Inventor Pro 2018.1
Win7 Pro x64
Intel i7-3930K 3.2 GHz; 32 GB RAM; GeForce GTX 680; SSD
Dell T5500
Vista Business x64
Inventor Pro 2018.1
Win7 Pro x64
Message 5 of 9
jasonh70
jasonh70
We're about half and half of users with 32 bit and 64 bit. 90% of our crash issues are on the 64 bit machines. No error report screen given.
Inventor Professional 2014 Build 222
Dell Precision T3500, Intel Xeon W3550 3.07 GHz, 12GB RAM, Win7 SP1
Message 6 of 9
Reasons for crashing..... Probably catch some flak on this reply..... in
order of frequency:
#1 - Graphics Cards and Drivers or system memory. Other issues can
contribute - undersized power supplies not properly supporting high end
Graphics card power needs, etc.
#2 - Improper Inventor installations -
#3 - User Error -
#4 - External hardware/Drivers - ie; 3D controllers, auxillary equipment,
including network hardware issues
#5 - Network CRC failures - Try running locally and see if the crashes stop.
#6 Random bugs... usually an extremenly small percentage.
Running IV2010 and 2009 here on xp64 8GB. Dead stable.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
http://teknigroup.com
order of frequency:
#3 - User Error -
Message 7 of 9
PACDrafting
PACDrafting
Hi Dennis
Can you expand on the improper Inventor installs?
Hi Dennis
Message 8 of 9
Here's an updated install sheet that lists the most important areas:
http://teknigroup.com/tutorials/InstallAdsk2009.html
Message 9 of 9
jon.myers
jon.myers
Looks like our stability issues may have been caused by another program that we recently installed. Our applications support team have had some preliminary success solving the crash issues after this program was un-installed. We should know pretty soon if that is the case. I will update our progress.
Thanks, Jon
Thanks, Jon
