1/ Insert Constraint. Rotation Not Locking. 2/ Sketch in Assy.
p_parker
p_parker
I have placed a level switch ( Blue Solid, imported from a dwg file ) into an assembly and constrained it with Insert. I have checked the lock rotation but it will still rotate. I could lock to another plane but this should work. No ?
Also. Can I sketch in an assembly do I have to start a new part ? I have tried to sketch and th esketch options are grayed out. I have turned off the Express Load option.
File attached.
Regards
Paul
johnsonshiue
Hi! I took a look. The issue is actually "P878-005-04:1."  It still has rotational degree of freedom. So, the lock rotates with it. You need to reduce the rotational dof on "P878-005-04:1."
Many thanks!
Software Test Engineer
p_parker
Hi Johnson,
Ha yes ! The insert constraint does not work on the hole cut in the conical component. I forgot to delete it.
Thanks for your prompt response.
Regards
Paul
