How to set VS2015 (not Shell) to work with ETO 2019 correctly?
After installation of ETO, VS2015 ETO extension is not working properly - but VS2015 shows ETO v8.0 under Extensions. It raises "Object reference not set to an instance of an object" error after each Intent command in *.iks designs.
Re-installing of ETO2019 does not help.
I could set the VS2013-Shell to work with ETO 2018 with C:\Program Files\Autodesk\Inventor ETO 2018\Bin\vsExtensionRestore.vbs, but I would like to use VS.
What I did not expect is that VS2013 works now with ETO from 2017 to 2019 - but not ETO2016 (shortly tested only, but with 2017-19 combinations I can see the root tree of ETO Model Browser, Function Navigator and see that VS completes the syntax without above given error - everything what VS2015 does not...)
Or... Maybe I should start the ETO 8 with VS 2015 shell, how?
regards
Tomasz,
Were you able to reach a solution to this issue? I am experiencing the same issue after updating to ETO 2020 with Visual Studio 2015.
I found that you can remove the autocomplete function and you are not bombarded by error messages:
Tools>Options>Text Editor>IntentV3>General:
Uncheck option "Auto list members"
I think this is a bug in the extension file "ETOSeriesStudio.EditorExtensions.dll"
It is one file that is a different size between versions.
do you know if the actually works properly if using VS2015 Shell?
Autodesk; please look into this, it is quite a bother. I have attached a video listing the error in action.
it happens ANYTIME I am trying to use autocomplete function:
Parameter
Rule
As
:DesignName
etc.
Thanks in advance!
