VS2015 (not Shell) with ETO 2019
How to set VS2015 (not Shell) to work with ETO 2019 correctly?
After installation of ETO, VS2015 ETO extension is not working properly - but VS2015 shows ETO v8.0 under Extensions. It raises "Object reference not set to an instance of an object" error after each Intent command in *.iks designs.
Re-installing of ETO2019 does not help.
I could set the VS2013-Shell to work with ETO 2018 with C:\Program Files\Autodesk\Inventor ETO 2018\Bin\vsExtensionRestore.vbs, but I would like to use VS.
What I did not expect is that VS2013 works now with ETO from 2017 to 2019 - but not ETO2016 (shortly tested only, but with 2017-19 combinations I can see the root tree of ETO Model Browser, Function Navigator and see that VS completes the syntax without above given error - everything what VS2015 does not...)
Or... Maybe I should start the ETO 8 with VS 2015 shell, how?
regards
Tomasz Malinowski
