PRINT PDF.......need help skipping reference
So the following code works too good.
It drills down through the BOM and prints PDFS of everything. The problem is that it prints everything including reference assemblies.
Can some one help me with a way to skip reference assemblies and parts.
Josh
SyntaxEditor Code Snippet
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
'get user input
RUsure = MessageBox.Show ( _
"This will create a PDF file for all of the asembly components that have drawings files." _
& vbLf & "This rule expects that the drawing file shares the same name and location as the component." _
& vbLf & " " _
& vbLf & "Are you sure you want to create PDF Drawings for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic  - Batch Output PDFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
'- - - - - - - - - - - - -PDF setup - - - - - - - - - - - -
oPath = ThisDoc.Path
PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If PDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
'oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2'oOptions.Value("Custom_End_Sheet") = 4
'get PDF target folder path
oFolder = oPath & "\" & oAsmName & " PDF Files"
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
'- - - - - - - - - - - - -Component Drawings - - - - - - - - - - - -'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models'this expects that the model has a drawing of the same path and name
For Each oRefDoc In oRefDocs
idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw"
'check to see that the model has a drawing of the same path and name
If(System.IO.File.Exists(idwPathName)) Then
        Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.Documents.Open(idwPathName, True)
    oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName) -3)
    'INSERT RULE HERE
    On Error Resume Next ' if PDF exists and is open or read only, resume next
     'Set the PDF target file name
    oDataMedium.FileName = oFolder & "\" & oFileName & "pdf"
        'Write out the PDF
    Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
    'close the file
    oDrawDoc.Close(True)
Else
'If the model has no drawing of the same path and name - do nothing
Next
'- - - - - - - - - - - - -Top Level Drawing - - - - - - - - - - - -
oAsmDrawing = ThisDoc.ChangeExtension(".idw")
oAsmDrawingDoc = ThisApplication.Documents.Open(oAsmDrawing, True)
oAsmDrawingName = Left(oAsmDrawingDoc.DisplayName, Len(oAsmDrawingDoc.DisplayName) -3)
'write out the PDF for the Top Level Assembly Drawing file
oDataMedium.FileName = oFolder & "\" & oAsmDrawingName & "pdf"
'Write out the PDF
Call PDFAddIn.SaveCopyAs(oAsmDrawingDoc, oContext, oOptions, oDataMedium)
'Close the top level drawing
oAsmDrawingDoc.Close
MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
'open the folder where the new ffiles are saved
Shell("explorer.exe " & oFolder,vbNormalFocus)
HermJan.Otterman
I added a few lines..
Exit Sub
'get user input
& vbLf & " " _
Return
Else
	 ' added
	 If oRefDoc.ComponentDefinition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure Then
		 'skip
	 Else
    'INSERT RULE HERE
        'Write out the PDF
    'close the file
Else
' added
Next
'Write out the PDF
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
MechMachineMan
In case like this, you should be also checking to ensure that the only instances of the parts don't have OVERRIDDEN occurrence BOM Structures. I believe your code is simply checking the DEFAULT which is set in the document.
You should either be iterating through the Structured BOM (as it properly excludes ALL reference parts), or add in more coding to iterate through the occurrences and skip the occurrences and their children if they are reference components.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Herm Jan Otterman.
Thanks for the help.
So here is what happened.
It skipped any top level files marked reference, ie. 707-007-2014.iam
But it printed all the files in 707-007-2014.iam.
ie
707-007-2014.iam skipped
-707-007-0107.ipt
-707-007-0108.ipt
-707-007-0109.ipt
-707-007-0110.ipt
Any Ideas?
Should I rewrite the script to just look at the "Structured" and "PARTS ONLY" bom's?
MechMachineMan
Using BOM's is definitely the most straightforward, otherwise you need to write a custom function to go through the "assembly structure" to the top level checking if any of the parent parts are reference. As you have found, it's obviously missing that the "Reference status" as inherited by a parent is not stored in the occurrence information Smiley Sad
Justin K
Here is what we came up with
If anyone has a shorter version please post
Sub Main()
Exit Sub
'get user input
& vbLf & " " _
Return
Else
doc = ThisDoc.Document
    Dim oAssyDef As AssemblyComponentDefinition = doc.ComponentDefinition
    Dim oBOM As BOM = oAssyDef.BOM
    oBOM.StructuredViewEnabled = True
    oBOM.StructuredViewFirstLevelOnly = False
    Dim oBOMView As BOMView = oBOM.BOMViews.Item("Structured")
    Dim oBOMRow As BOMRow
    Dim oCompDef As ComponentDefinition
    For Each oBOMRow In oBOMView.BOMRows
       If Not oBOMRow.ChildRows Is Nothing
         Call RecurseBOMRow(oBOMRow, PDFAddIn, oFolder)
       oCompDef = oBOMRow.ComponentDefinitions.Item(1)
idwPathName = Left(oCompDef.Document.FullDocumentName, Len(oCompDef.Document.FullDocumentName) - 3) & "idw"
'check to see that the model has a drawing of the same path and name 'MessageBox.Show(idwPathName)
    oFileName = Left(oCompDef.Document.DisplayName, Len(oCompDef.Document.DisplayName) -3)
    'INSERT RULE HERE
    iLogicVb.Automation.RunExternalRule(oDrawDoc, "DELETE1")
    iLogicVb.Automation.RunExternalRule(oDrawDoc, "DELETE2")
        'Write out the PDF
    'close the file
Else
    Next
Call PrintTopLevel()
End Sub
Sub RecurseBOMRow(oBOMRow As BOMRow, PDFAddIn As ApplicationAddIn, oFolder As String)
   For Each oBOMRow In oBOMRow.ChildRows
    'INSERT RULE HERE
    'On Error Resume Next ' if PDF exists and is open or read only, resume next
        'Write out the PDF
    'close the file
Else
   Next
End Sub
Sub PrintTopLevel()
oAsmDrawing = Left(ThisApplication.ActiveDocument.FullDocumentName, Len(ThisApplication.ActiveDocument.FullDocumentName) - 3) & "idw"
 'oFolder = "C:\Work\Projects\24000\24373\24373-007-7000 PDF Files"
'Write out the PDF
End Sub
MechMachineMan
In this case, I'd probably cheat and use global variables, as well as taking full advantage of the recursion as such:
Sub Main()
'Pre Rule Checks
		Exit Sub
		& vbLf & " " _
		Return
		Else
'/Pre Rule Checks
	Dim oAssyDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
	oAsmPathAndName = Left(oAsmDoc.FullFileName, Len(oAsmDoc.FullFileName) - 4)
	oAsmDrawingDoc = ThisApplication.Documents.Open(oAsmPathAndName & ".idw", True)
	oAsmDisplayName = Left(oAsmDrawingDoc.DisplayName, Len(oAsmDrawingDoc.DisplayName) -4)
	oFolder = oPath & "\" & oAsmDisplayName & " PDF Files"
	Call ConfigPDFSettings(oFolder)
	'Print Top Level
	oDatamedium.FileName = oFolder & "\" & oAsmDisplayName & ".pdf"
	Call PDFAddIn.SaveCopyAs(oAsmDrawingDoc, oContext, oOptions, oDatamedium)
 	Call RecurseandPrintBOMRows(oBOMView.BOMRows)
End Sub
	Dim oFolder As String
	Dim oContext
	Dim oOptions
	Dim oDatamedium
	Dim PDFAddIn
	Sub RecurseandPrintBOMRows(oBOMRows As BOMRowsEnumerator)
		For Each oBOMRow In oBOMRows
				oFileName = Left(oCompDef.Document.DisplayName, Len(oCompDef.Document.DisplayName) - 3)
				oDatamedium.FileName = oFolder & "\" & oFileName & "pdf"
				Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDatamedium)
			Else
				Call RecurseandPrintBOMRows(oBOMRow.ChildRows)
		Next
	End Sub
	Sub ConfigPDFSettings(oFolder As String)
		oDatamedium = ThisApplication.TransientObjects.CreateDataMedium
		If PDFAddIn.HasSaveCopyAsOptions(oDatamedium, oContext, oOptions) Then
	End Sub
Justin K
