Open a file with VBA Inventor
Message 1 of 15
Hello Cany you tell me how can i open a file with VBA from Invenotr Thanks
Replies (14)
Message 2 of 15
MechMachineMan
I'm sure google could accomplish the task of answering this exact question.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 15
I found this but id doesent work, can you help me?
Sub OpenDoc()
Dim oDoc As Document
oDoc = _InvApplication.Documents.Open _
("C: Temp\Part1.ipt")
End Sub
Message 4 of 15
MechMachineMan
If you are using VBA rather than vb.net you will need to use Call And Set.
ie; Sub OpenDoc() Dim oDoc As Document Set oDoc = _InvApplication.Documents.Open("C: Temp\Part1.ipt") End Sub
Justin K
Message 5 of 15
Message 6 of 15
MechMachineMan
Try putting it on separate lines.
Justin K
Message 7 of 15
Hello when i try to start my project in VB i bekommen this message:
Message 8 of 15
rossano_praderi
Set objExcel = CreateObject("Excel.Application")
Set objWorkbook = objExcel.Workbooks.Open("c:\test.xls")
objExcel.Application.Visible = True
objExcel.ActiveWorkbook.Close
objExcel.Application.Quit
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Message 9 of 15
Sorry for tagging onto an old thread, but how could I do this to open a .txt file?
Message 10 of 15
frederic.vandenplas
Process.Start("c:\example.txt")
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Message 11 of 15
It comes up with object required?
Message 12 of 15
frederic.vandenplas
This should work
Sub OpenTextFile()
Dim oTextFile As Variant
oTextFile = Shell("notepad.exe ""C:\test.txt""", vbNormalFocus)
End Sub
Message 13 of 15
Thank you! This is perfect 🙂
Message 14 of 15
This works for me but only as Read-Only, any insights on how to fix this?
Message 15 of 15
rossano_praderi
when we use the Excel application object you should use the help of that application as reference.
The follow option to control read/write mode for the "Open" method.
Set objWorkbook = objExcel.Workbooks.Open("c:\test.xls",, False)
 For reference see...
https://msdn.microsoft.com/en-us/VBA/Excel-VBA/articles/workbooks-open-method-excel
Bregs
Rossano Praderi
