Inventor 2022 Derived parts - Unable to toggle construction lines on or off.
iUser
Message 1 of 11
iUser
Hi all,
In Inventor 2021 we used to be able to derived a part's sketches and toggle lines from construction to solid and vice versa. Seems like in Inventor 2022 they have disabled this function. Can you please re-enable this? Now our current work-around is to create a new sketch and project those lines. Adding an unnecessary step...
Replies (10)
Message 2 of 11
bradeneuropeArthur
Hi @iUser
This is really no good situation I think!
What happens during migration?
This was possible in earlier releases of inventor and now not anymore.
Will this lead into problems when files are migrated with construction-lines into normal lines, I think YES.
@johnsonshiue Could you check with the team if this is the case:
  • Migrated files giving error regarding this option removed.
  • If this can be given back to the users.
I really hope that Inventor 2022 will not give that much problems for users also regarding other changes!
Regards
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 11
Having similar issue with this and need some feed back as soon as possible. Our company uses this function all the time and has many files using this feature. we just recently updating to 2022 so it wasn't an issue until now. Please let me know if there is some feature check box we need to check. Thanks.
Message 4 of 11
bradeneuropeArthur
@johnsonshiue could you please check for a solution for all of us!
Thanks in advance.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 11
nielsBY9GF
Have the same problem, if someone has an solution it would be great.
Message 6 of 11
bradeneuropeArthur
I have real big problems with this change too.
  • For migration planning we need to know what will happen during migration.
  • For new created files we need to make Users aware of this.
@johnsonshiue Could you please be so kind to help us with a solution.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 11
yeah... wtf is up with this? BIG problem
Message 8 of 11
2 months and not a peep, from @johnsonshiue or anyone at Autodesk?
Message 9 of 11
iUser
@johnsonshiue or @Yijiang.Cai could you guys please have a look at this? Its starting to cause more and more issues and the work arounds are starting to cost us time and money.
Message 10 of 11
bradeneuropeArthur
Please read this:
https://forums.autodesk.com/t5/inventor-forum/derived-part-cant-change-line-types-from-sketches-i-pu...
Think that the issue has been taken serious now from the development team!
Thanks again @johnsonshiue for taking this serious!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 11
Yijiang.Cai
@iUser , today I talked with @johnsonshiue about this issue, and Johnson is working with project team on it.
@johnsonshiue , please feel free to share more details here if you have.
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
