Inv2022 - Replace model reference via API
CattabianiI
CattabianiI
The Replace Model Reference drawing command has been updated to manage the model states, it gives the ability to replace the referenced document in its model state (model state member document).
In previous Inventor versions I implemented this functionality with FileDescriptor.ReplaceReference but now I need to work at a document level not file level to implement the Replace Model Reference behaviour via API.
By the way the lack of API is something already came up in certain pattern like this one
Now with model states is even more necessary.
Is there something I am missing and it's already doable? Could you please add an api otherwise?
bradeneuropeArthur
Does this not work anymore:
Dim oPartDoc As Document 'PartDocument
            oPartDoc = ThisApplication.ActiveDocument
            Dim oRefPartDoc As DocumentDescriptor
            oRefPartDoc = oPartDoc.ReferencedDocumentDescriptors.Item("")
            oRefPartDoc.ReferencedFileDescriptor.ReplaceReference("")
            oPartDoc.Update()
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
