iLogic rule not working with Inventor 2019
drafting03_AR
drafting03_AR
I managed to cobble together some code that takes the current open drawing and exports it as an ACAD 2000 .dwg file into a certain folder. However, after updating from Inventor 2017 to Inventor 2019, it no longer works. The particular line of code that has the error is:
DWGAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
The full code is here:
' This rule will publish the currently open Inventor drawing to an AutoCAD .dwg (2000). Note that it will also publish non-sheet metal dwgs
Imports SysIO = System.IO
Sub Main()
	'See if there are any open views
	If (ThisApplication.Views.Count > 0) Then
		'Setup Translator to dwg
		Dim DWGAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
		Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
		oContext.Type = kFileBrowseIOMechanism
		' Create a NameValueMap object
		Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
		' Create a DataMedium object
		Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
		'Go through each view and save if it's a drawing document
		Dim oDoc = ThisDoc.Document
			If oDoc.DocumentType = kDrawingDocumentObject Then
				'Get the directory file is saved in. Can replace this with specific directory
				'Dim dwgDir = SysIO.Path.GetDirectoryName(view.Document.FullFileName)
				Dim dwgDir = "\\ARD-ad01\CompanyData\ACUTE AND LASER CUTTING DWG DXF STEP PDF\"
				'Get name of file without the extension and add _acad2k to it.
				oDataMedium.MediumType = kFileNameMedium
				oDataMedium.FileName = dwgDir & "\\" & _
                                    SysIO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) & _
                                     ".dwg"
				' Check whether the translator has 'SaveCopyAs' options
				If DWGAddIn.HasSaveCopyAsOptions(oDoc, oContext, oOptions) Then
					'Use Export To DWG to save drawing configuration and set here
					Dim strIniFile As String = "C:\\Temp\\DWGOut.ini"
					' Create the name-value that specifies the ini file to use.
					oOptions.Value("Export_Acad_IniFile") = strIniFile
					' Set the DWG version.
        			' 23 = ACAD 2000
        			' 25 = ACAD 2004
        			' 27 = ACAD 2007
        			' 29 = ACAD 2010
        			oOptions.Value("DwgVersion") = 23
					'Save File
					ThisApplication.[_LibraryDocumentModifiable] = True
					question = MsgBox("AutoCAD DWG Created:" & vbLf & vbLf & oDataMedium.FileName & vbLf & vbLf & "Would you like to open it?", MsgBoxStyle.YesNo, "Ausroad iLogic")
					If question = vbYes Then
						ThisDoc.Launch(oDataMedium.FileName)
			Else
				MsgBox("File must be a DWG", MsgBoxStyle.OKOnly, "Ausroad iLogic")
End Sub
The error message is:
Error in rule: ExportDWG, in document: 50034A.dwg
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
More Info:
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
   at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
   at Inventor.TranslatorAddIn.SaveCopyAs(Object SourceObject, TranslationContext Context, NameValueMap Options, DataMedium TargetData)
   at ThisRule.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Anyone have any idea how I can fix this? We went from Inventor 2017 to 2019, OS is Windows 7 Pro x64.
Or is there a simpler way to achieve an ACAD 2000 .dwg export with a rule? I'm pretty sure I have some redundant code in there but it worked, so I just left it alone.
bradeneuropeArthur
Something is wrong with the path on your server!
if you test this line of code it works:
Dim dwgDir = "c:\temp\"
and not using this string
'"\\ARD-ad01\CompanyData\ACUTE AND LASER CUTTING DWG DXF STEP PDF\"
did you change your server name or paths!?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
