iLogic - Made PDF w/ REV
Hi Everyone,
We have successfully used the code w/in Curtis's iLogic code located here: http://inventortrenches.blogspot.com/2011/07/ilogic-to-save-pdf-files-to-new.html.
It appears to no longer work now w/ Inventor 2018.  I receive the error "Invalid pointer (Exception from HRESULT: 0x80004003 (E_POINTER))"
Any ideas or suggestions??
Thanks!
Todd Peterson
MechMachineMan
Hi. Question has been addressed at least twice in the last 6 months on the forums.
The line
oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
is no longer supported in 2018.
Remove that, and it should work. Otherwise, search the forums harder for a solution someone else has posted.
Good luck.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thank you.
