How to Join lines in Inventor?
In AutoCAD you just type Join into the command line... Can you join lines together in Inventor too?  It would be really nice to join lines together before offset...
HermJan.Otterman
The hardest thing to do is forgetting the way you work in Autocad.
If you have two lines collinear, that are somewhere in the middle connected, and each have the other end connected to the rest of the lines, just delete one of the two lines and connect the open end point to the other open end point by dragging the endpoint of the line or by using the coinsident constraint.
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
MechMachineMan
Also, the extend command can be used after deleting one of the lines to join it to the other line, provided they will intersect at some point.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Easiest way I know how is to you the trim command (Short Cut Key: X) then hold shift to extend/join the lines together.
frederic.vandenplas
Before you make a selection, look at the right mouse butten options, there is an option to select a loop, or just to select the line.
If lines are connected with coincident constraint, no join is needed in Inventor.
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
