Message 1 of 19
Hi Guys,
I would like to check two files via API and currently I use the internalname property for this but I have to open the document first.
If I want to process lot of files particularly big files then the process is too slow because of the open command.
One of the two comparable internal name comes from a file referece using the "FileDescription.ReferencedFileInternalName" only the second one should be read from file.
Is there a way to get the internal name of the documents directly from the files without open them?
Thanks in advance.
Attila Farkas
