How does Frame Generator identify members?
JhoelForshav
Mentor Mentor
Message 1 of 14
JhoelForshav
I wonder which property whithin the part frame generator uses to identify this value? When you click "Change" in the Design-tab and select a component the current size gets pre-selected.
I've tried changing PropertySets.Item("Content Library Component Properties").Item("MemberId") but it has no effect on the pre-selection.
Replies (13)
Message 2 of 14
bradeneuropeArthur
For these files inventor uses additional property sets with properties!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 14
JhoelForshav
Hi @bradeneuropeArthur
I thought that might be the case...
Are you sure there's no way to access them through API?
Message 4 of 14
bradeneuropeArthur
yes you can.
By searching for the Property:
Design Tracking Properties >>  Size Designation  = *****
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 14
JhoelForshav
My code to change a frame member identifies the selected occurrences family and member id, then lets you select a new member id from that family. Then it changes all the mapped parameters and properties according to the family table to those of the new member id. So I already change the size designation property. This has no effect on the pre-selected size in the change command 😞
Message 6 of 14
JhoelForshav
I believe it has something to do with this:
ContentTableColumn.HasPropertyMap returns false for my column with internal name SIZE however.
I cant find "Section Designation" in any propertyset in the document. The closest I've gotten to find anything that seems to have something to do with this is the property "Categories" in Design Tracking Properties. I copied this property value (a very long string) from one occurence of size "UPE 100" to one of size "UPE 300". Still no result...
Message 7 of 14
bradeneuropeArthur
Try it this way, I am searching too!
Design Tracking Properties >> Categories	 ConstantValue="THIS SCHOULD BE YOUR VALUE><ParamToTemplate CategoryParameter="//CategoryParameter[@InternalName='****************']" ConstantValue="3"/><ParamToTemplate
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 14
bradeneuropeArthur
You are searching in the same direction!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 14
bradeneuropeArthur
It could be possible that the name is from the Content Center Family table via the internal property within the file.
You could test it to disable the Content Center from using...
if the result is empty then, then this is a value that is populated from the table and not form the file it selves.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 14
JhoelForshav
This is very intetesting!
I did as you said. Created a new project file with no library included and opened the file from there. This resulted in this:
When selecting the change command the list does not populate at all. Then when i select the frame member I get the Size designation as Size. Category, Standard and Family are also auto filled after the member is selected. I selected a member that has already been changed by my code.
So now it in fact is the size designation.. However the size designation contains " -0,001" . According to my family table that is correct.
But when a member is changed or placed with content center the value in the list does not contain this "0,001".
Also then i think the value comes from the key-column "Variety" with internal name "SIZE". So in other words it is not the size designation in that case.
This is some confusing stuff...
Message 11 of 14
JhoelForshav
If I place a member via Frame Generator and then suppress that members row in the family table it is Design Tracking Properties -> Size Designation that controls the name of the member in the dropdown list when i try to change it with Frame Generator... If it does exist in content center however I get the name from here:
Somewhere in the partdocument the information about which row to read the SIZE from must exist...
I thoght it should be "Content Library Component Properties" -> "MemberID" but it's not...
Message 12 of 14
JhoelForshav
OK... So i tried placing two different members of different sizes. Then selected one of them -> component -> replace, and selected the other one. After that chose it with the change command. To my surprise the old size value (from the component i replaced) was pre selected. This must mean that the information is not stored in the parts after all.
Maybe it's stored somewhere in the Frame assembly or in the Frame Reference Model...
Message 13 of 14
bradeneuropeArthur
Maybe these are stored in attributes!
You could check if there are attributes defined!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 14
JhoelForshav
I found an attribute for the specific path in the skeleton in the frame members document.
Then in the frame assembly i found an attribute describing the members in the frame with skeleton path, family and family row! With this code i could match the skeleton path from the specific frame member to the section of the assemblies attribute describing that member. Replacing the row number for the member in the assemblys attribute did the trick.
The code could use a bit of cleaning, but at least it works now 🙂
Imports Inventor
Public Class Form1
    Dim invApp As Inventor.Application = GetObject(, "Inventor.Application")
    Dim oDoc As AssemblyDocument = invApp.ActiveDocument
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        CustomMember_ChangeRow()
    End Sub
    Sub CustomMember_ChangeRow()
        Dim i As Integer
        Dim oAsmDoc As AssemblyDocument
        oAsmDoc = invApp.ActiveDocument
        Dim oAsmDef As AssemblyComponentDefinition
        oAsmDef = oAsmDoc.ComponentDefinition
        Dim oOcc As ComponentOccurrence
        oOcc = invApp.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "välj balk")
        Dim oDef As PartComponentDefinition
        oDef = oOcc.Definition
        If oDef.IsContentMember Then
            MsgBox("this sample works with the custom CC member only")
            Exit Sub
        Else
            Debug.Print("It's a Custom CC member")
        Dim oDoc As PartDocument
        oDoc = oDef.Document
        Dim oProps As PropertySet
        oProps = oDoc.PropertySets.Item("Content Library Component Properties")
        Dim oProp As Inventor.Property
        oProp = oProps.Item("FamilyId")
        Dim FamilyId As String
        FamilyId = oProp.Value
        Dim oContentCenter As ContentCenter
        oContentCenter = invApp.ContentCenter
        Dim oFamily As ContentFamily
        oFamily = oContentCenter.GetContentObject("v3#" + FamilyId + "#")
        oProp = oProps.Item("MemberId")
        Dim MemberId As String
        MemberId = oProp.Value
        Dim newRow As Integer
        newRow = InputBox("Current Family row is " & MemberId _
            & vbNewLine & vbNewLine & "New Family row:",
            "New Family Row:", MemberId)
        Dim oRow As ContentTableRow
        oRow = oFamily.TableRows.Item(newRow)
        Dim nCol As Integer
        Dim oColumn As ContentTableColumn
        Dim oPar As UserParameter
        Dim oCustomProps As PropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
        For Each oPar In oDef.Parameters.UserParameters
            If oPar.DrivenBy.Count = 0 Then
                nCol = -1
                For i = 1 To oFamily.TableColumns.Count
                    If oFamily.TableColumns.Item(i).InternalName = oPar.Name Then
                        nCol = i
                        Exit For
                Next
                If nCol <> -1 Then
                    oColumn = oFamily.TableColumns.Item(nCol)
                    If oColumn.KeyColumnOrder > 0 Then
                    Else
                        Dim units As String
                        units = oColumn.Units
                        Dim oCell As ContentTableCell
                        oCell = oRow.Item(nCol)
                        Dim value As String
                        value = oCell.Value & " " & units
                        oPar.Expression = value
                        Try
                            oCustomProps.Item(oPar.Name).Value = value
                        Catch ex As Exception
                        End Try
        Next
        oProp.Value = newRow
        oProp = oProps.Item("Member Revision")
        oProp.Value = CreateGuid()
            oColumn = oFamily.TableColumns.Item(i)
            If oColumn.HasPropertyMap = True Then
                Dim setid As String = String.Empty
                Dim propid As String = String.Empty
                Dim units As String
                Try
                    If oColumn.InternalName <> "PARTNUMBER" Then
                        oColumn.GetPropertyMap(setid, propid)
                        Dim oExpression As String = oColumn.Expression
                        oExpression = Replace(Replace(oExpression, "&", ""), Chr(34), "")
                        Dim inS As String = oExpression
                        Dim oColl As New Collection
                        Dim s As String
                        Dim j As Integer, k As Integer
                        Do
                            j = InStr(1, inS, "{")
                            k = InStr(1, inS, "}")
                            If (j = 0) Or (k = 0) Then Exit Do
                            s = Mid$(inS, j + 1, k - j - 1)
                            If s <> "" Then
                                Call oColl.Add(s)
                                inS = Mid$(inS, k + 1, Len(inS))
                        Loop Until s = ""
                        Dim ss As Object
                        For Each ss In oColl
                            Try
                                Dim oParam As UserParameter
                                Try
                                    oParam = oDef.Parameters.UserParameters.Item(ss)
                                    s = oParam.Expression
                                    Debug.Print(s)
                                    s = Microsoft.VisualBasic.Left$(s, InStr(s, " ") - 1)
                                    Debug.Print(s)
                                Catch
                                    s = ""
                                    For colIndex = 1 To oFamily.TableColumns.Count
                                        If oFamily.TableColumns.Item(colIndex).InternalName = ss Then
                                            s = oRow.Item(colIndex).Value
                                            Exit For
                                    Next
                                    Debug.Print(s)
                                End Try
                            Catch
                            End Try
                            oExpression = Replace$(oExpression, "{" & ss & "}", s)
                        Next
                        Try
                            oDoc.PropertySets.Item(setid).ItemByPropId(propid).Value = oExpression &
                                If(units IsNot Nothing, " " & units, Nothing)
                        Catch
                            oDoc.PropertySets.Item(setid).Item(propid).Value = oExpression &
                        End Try
                Catch
                    MsgBox("Failed to update: " & oColumn.InternalName)
                End Try
        Next
        ChangeAttributes(oOcc, newRow, FamilyId, GetPathID(oOcc))
        oDoc.Update()
        oDoc.Save()
        oAsmDoc.Update()
        oAsmDoc.Rebuild2()
        Beep()
    End Sub
    Function GetPathID(oOcc As ComponentOccurrence) As String
        Dim oDef As PartComponentDefinition = oOcc.Definition
        Dim oDoc As PartDocument = oDef.Document
        Dim FGPaths As String = oDoc.AttributeManager.FindAttributes("com.autodesk.FG*", "Paths", "*").Item(1).Value
        Return FGPaths.Split("""")(1)
    End Function
    Sub ChangeAttributes(oOcc As ComponentOccurrence, newRow As Integer, FamilyID As String, oPath As String)
        Dim oParent = oOcc.ContainingOccurrence
        While True
            Dim AttributesEnum As AttributesEnumerator = oParent.Definition.Document.AttributeManager.FindAttributes("com.autodesk.FG*", "Frame.Skeletons", "*")
            If AttributesEnum.Count > 0 Then
                Dim oS As String = AttributesEnum.Item(1).Value
                Dim StartIndex As Integer = oS.IndexOf(oPath)
                Dim oNewContent As Integer = oS.IndexOf("MonikerForNewContent", StartIndex)
                Dim oNumber As Integer = oS.IndexOf(FamilyID, oNewContent)
                Dim oMember As Integer = oS.IndexOf("#", oNumber) + 1
                Dim oIntegers As Integer = 1
                While True
                    If IsNumeric(oS(oMember + oIntegers)) Then
                        oIntegers += 1
                    Else
                        Exit While
                End While
                oS = oS.Substring(0, oMember) & newRow & oS.Substring(oMember + oIntegers)
                oNewContent = oS.IndexOf("MonikerForCC", StartIndex)
                oNumber = oS.IndexOf(FamilyID, oNewContent)
                oMember = oS.IndexOf("#", oNumber) + 1
                oIntegers = 1
                While True
                        oIntegers += 1
                    Else
                        Exit While
                End While
                AttributesEnum.Item(1).Value = oS
                Exit While
            Else
                Try
                    oParent = oParent.ContainingOccurrence
                Catch
                    MsgBox("Error")
                    Exit While
                End Try
        End While
    End Sub
    Private Function CreateGuid()
        ' Returns a unique Guid on every call. Removes any cruft.
        ' https://msdn.microsoft.com/en-us/subscriptions/sh9ete15(v=vs.84).aspx
        ' http://stackoverflow.com/questions/968756/how-to-generate-a-guid-in-vbscript
        CreateGuid = Mid$(CreateObject("Scriptlet.TypeLib").GUID, 2, 36)
    End Function
End Class
