Announcements
Export Assembly BOM with Parent Part numbers
I have a need to use my BOM in another program that has the ability to import complex assemblies in one import.
It uses a "parent part number" field to identify the assemblies.
Anyone have any ideas? I manually added a field and populated it to give you an idea of what I'm looking for.
I left in the "Item" column for a clear picture of the hierarchy, but that isn't necessary for my import.
Part Number, Parent Part Number, Quantity, Unit Quantity
are my minimum fields.
Replies (8)
bradeneuropeArthur
What is the file format you are needing for the export.
Question:
What are you trying to do with this exported BOM.
Maybe there are less complex methods to achieve the same as you are needing!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
The preferred format is .csv
I am importing into an ERP system that creates routers and work orders. It requires a specific import template as I listed.
I can import each assembly one by one - but if I can figure this out (with the parent part numbers) then I can do it in one import.
bradeneuropeArthur
What if the Childfile is used in more than one parent?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
I am using a "Structured" list with expanded assemblies to give me the following - notice the item numbers that Inventor populated (4.1 is a child of 4): parts are repeated if they are in multiple assemblies.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Anonymous,
Try the following suggestion to customize BOM.
https://www.cadlinecommunity.co.uk/hc/en-us/articles/203364071-Inventor-2017-Quick-Tip-BoM-Customisation-
To import customized BOM, try the following VBA code to import.
Sub BOM_ColumnCustomizasion_Export ()
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmDef As AssemblyComponentDefinition
Set oAsmDef = oAsmDoc.ComponentDefinition
Dim oBOM As BOM
Set oBOM = oAsmDef.BOM
Dim filename As String
filename = "c:\temp\BOM_Columns.xml"
Call oBOM.ExportBOMCustomization(filename)
Beep
End Sub
Sub BOM_ColumnCustomizasion_Import ()
Dim oBOM As BOM
Dim filename As String 'assume the file exists
Call oBOM.ImportBOMCustomization(filename)
Beep
End Sub
After importing BOM, try to export BOM using following VBA code.
Public Sub BOMExport()
    ' Set a reference to the assembly document.
    ' This assumes an assembly document is active.
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    ' Set a reference to the BOM
    Dim oBOM As BOM
    Set oBOM = oDoc.ComponentDefinition.BOM
    ' Set the structured view to 'all levels'
    oBOM.StructuredViewFirstLevelOnly = False
    ' Make sure that the structured view is enabled.
    oBOM.StructuredViewEnabled = True
    ' Set a reference to the "Structured" BOMView
    Dim oStructuredBOMView As BOMView
    Set oStructuredBOMView = oBOM.BOMViews.Item("Structured")
    ' Export the BOM view to an Excel file
    oStructuredBOMView.Export "C:\temp\BOM-StructuredAllLevels.xls", kMicrosoftExcelFormat
End Sub
Hope, this would help you to import assembly with Parent Part Number.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Thanks Chandra, this looks very promising. I will dig into it and see what I come up with.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous - let me know if any assistance required.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Brett.G
Nick,  were you ever able to figure out a solution?  This functionality is something I'd be interested in as well.  Thanks!
Type a product name
