Create Copy with ilogic
jam_bhatti
Message 1 of 24
jam_bhatti
I have done a Vessel Nozzle with options as sub assembly and need to create a clone at same location with all constraints.
is it possible by ilogic rule.
mean just click copy button on form and create same nozzle at current spot. then i move to another locations to create other nozzle with different sizes.
Replies (23)
Message 2 of 24
jam_bhatti
i am waiting response from forum. any comment.
Is it difficult to do or not possible?
Message 3 of 24
rossano_praderi
is possible and is not so difficult, but it take time.
Every person who is writing in this forum are doing it for free.
Then if you want answers, please be patient.
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Message 4 of 24
MechMachineMan
Have you thought of using iMates/Place iLogic component to accomplish the same thing?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 5 of 24
jam_bhatti
@MechMachineMan
Every time make a copy then place the exact location, these thing taking much time. so i want it by rule to save time.
Message 6 of 24
Balaji_Ram
Have you tried creating the assembly occurrence directly as in this code snippet ?
doc = ThisDoc.Document
Dim oAssyDoc As AssemblyDocument
oAssyDoc = doc
Dim oDef As AssemblyComponentDefinition
oDef = oAssyDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
oMatrix = ThisApplication.TransientGeometry.CreateMatrix()
oOcc = oDef.Occurrences.Item(1)
Call oAssyDoc.ComponentDefinition.Occurrences.Add(oOcc.Definition.Document.FullFileName, oMatrix)
oAssyDoc.Activate
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Message 7 of 24
MechMachineMan
Ok. But if you use iMates properly, you can just insert a new part and have it snap to the base plate thorough iMate, and then select it's location on the Grid of Planes again, using imates and just selecting those.
iMates can also be manipulated through the API as well so that's what I mean by you being able to speed it all up. Rather than placing a copy, selecting the constrain you want to modify to change it's location, then saving that.
Justin K
Message 8 of 24
jam_bhatti
@Balaji_Ram
Hi
Thanks for making this code, but i need the unique copy of assembly. the code creates assembly with same perameters and part names.
second things assembly having some parts as suppressed so need to be ignore these during copying.
please help me more about that.
SyntaxEditor Code Snippet
oAssyDoc = doc
oTG = ThisApplication.TransientGeometry
oOcc = oDef.Occurrences.Item(9)
oMatrix.SetTranslation(oTG.CreateVector(0, (NELV-SF)/10, 0))
oAssyDoc.Activate
Message 9 of 24
Balaji_Ram
Here are the steps to keep the sub-assembly independent when creating a new occurrence.
1. Ensure that all the parts in the sub-assembly are saved using a different part file name.
2. Replace all the parts in the sub-assembly and ensure they refer to the new part files created in step-1.
    In the Inventor UI, you would do this using Component->Replace
3. Save the modified sub-assembly as a different assembly file.
4. Create a sub-occurrence using the new modified sub-assembly.
This should ensure that the changes to the part files will not get propagated for all the sub-assemblies.
I haven't put them all together yet, but here are the individual parts to do the steps.
Hope this gives you some direction in the meantime.
For saving the sub-assembly :
oAssyDoc = doc
Dim oSubAssy As ComponentOccurrence
oSubAssy = oDef.Occurrences.Item(2)
Dim oSubAssyDef As AssemblyComponentDefinition
oSubAssyDef = oSubAssy.Definition
Dim oSubAssyDoc As AssemblyDocument
oSubAssyDoc = oSubAssyDef.Document
oSubAssyDoc.SaveAs("D:\Temp\MyNewSubAssy.iam", True)
For saving the parts in a sub-assembly
Dim i As Integer
i = 1
' Save the parts in the sub-assembly with a different file name.
For Each oOcc In oSubAssyOcc.SubOccurrences
	If (oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject) Then
		Dim oPartPath As String
		oPartPath = oOcc.Definition.Document.FullFileName
		MessageBox.Show(UCase(oOcc.Name) & " : " & oPartPath)
		oOcc.Definition.Document.SaveAs("D:\" & i & ".ipt", True)
	i = i + 1
Next
For replacing the parts in the sub-assembly :
 ' Replace the parts in the new sub-assembly with the newly created ones
i = 1
Dim oDef1 As AssemblyComponentDefinition
oDef1 = oSubAssyDoc1.ComponentDefinition
For Each oOcc In oDef1.Occurrences
		oOcc.Replace("D:\" & i & ".ipt", True)
	i = i + 1
Next
oSubAssyDoc1.SaveAs("D:\MyNewSubAssy.iam", False)
 For creating a new occurrence using the sub-assembly
' Load the modified sub-assembly
Call oAssyDoc.ComponentDefinition.Occurrences.Add("D:\MyNewSubAssy.iam", oMatrix)
oAssyDoc.Activate
Balaji
Balaji
Message 10 of 24
jam_bhatti
@Balaji_Ram
Hi
For saving the sub-assembly, code creates the whole main assembly. how can i assign to saveas target subassembly.
i am not expert in coding and can't fix it between other steps also. could you favor me to combine all things with test sub-assembly.
i will highly appriciate to help me and really helpfull in my project.
Best Regard's
Jamil
Message 11 of 24
Balaji_Ram
Hi Jamil,
Does this code snippet help ? It should create a new occurrence based on a sub-assembly. The new sub-assembly occurrence will refer to the copy of the part files, so can be modified independently.
In the code snippet, i am assuming that the first occurrence is a sub-assembly. You may need to tweak to suit your needs.
oAssyDoc = doc
Dim oAssyDef As AssemblyComponentDefinition
oAssyDef = oAssyDoc.ComponentDefinition
Dim oSubAssyOcc As ComponentOccurrence
oSubAssyOcc = oAssyDef.Occurrences(1)
Dim newPartPath As String
Dim newSubAssyPath As String
If (oSubAssyOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject) Then
	oSubAssyDef = oSubAssyOcc.Definition
	If (System.IO.File.Exists(oSubAssyDoc.FullFileName)) Then
		Dim fi As New System.IO.FileInfo(oSubAssyDoc.FullFileName)
		newSubAssyPath = System.IO.Path.Combine(New System.String() {fi.DirectoryName, fi.Name.Replace(fi.Extension, [String].Format("_New{0}", fi.Extension))})
    System.IO.File.Copy(oSubAssyDoc.FullFileName, newSubAssyPath, True)
	If (System.IO.File.Exists(newSubAssyPath) = False) Then
		MessageBox.Show(String.Format("Error copying the SubAssembly file {0}", oSubAssyDoc.FullFileName))
		Return
	' Create a copy Of the all the parts in the Sub-Assembly
	Dim oSubOcc As ComponentOccurrence
	For Each oSubOcc In oSubAssyOcc.SubOccurrences
		If (oSubOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject) Then
			Dim oPartDef As PartComponentDefinition
			oPartDef = oSubOcc.Definition
			Dim oPartDoc As PartDocument
			oPartDoc = oPartDef.Document
			If (System.IO.File.Exists(oPartDoc.FullFileName)) Then
				Dim fi As New System.IO.FileInfo(oPartDoc.FullFileName)
				newPartPath = System.IO.Path.Combine(New System.String() {fi.DirectoryName, fi.Name.Replace(fi.Extension, [String].Format("_New{0}", fi.Extension))})
			System.IO.File.Copy(oPartDoc.FullFileName, newPartPath, True)
			If (System.IO.File.Exists(newPartPath) = False) Then
				MessageBox.Show(String.Format("Error copying the part file {0}", oPartDoc.FullFileName))
				Return
		ElseIf (oSubOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject) Then
			MessageBox.Show(String.Format("SubAssembly {0} inside a SubAssembly. This case is not yet handled.", oSubOcc.Name))
			Return
	Next
	' Create a New occurrence Of the Sub-Assembly
    Dim oPosition As Matrix
	oPosition = ThisApplication.TransientGeometry.CreateMatrix()
	Dim oNewSubAssyOcc As ComponentOccurrence
	oNewSubAssyOcc = oAssyDoc.ComponentDefinition.Occurrences.Add(newSubAssyPath, oPosition)
    ' Replace the parts in the New Sub-Assembly
	For Each oSubOcc In oNewSubAssyOcc.SubOccurrences
            z
			If (System.IO.File.Exists(newPartPath)) Then
            	oSubOcc.Replace(newPartPath, True)
	Next
ElseIf (oSubAssyOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject) Then
	MessageBox.Show("Sorry, Expecting a subassembly to copy, but found " & UCase(oSubAssyOcc.Name))
Balaji
Balaji
Message 12 of 24
jam_bhatti
@Balaji_Ram
Your code snippet working superb for first attempt. but second copy make similar to the first copy. i am trying to check with different scenario with my subassembly and will provide with (screenshots/video) feed back shortly.
Thanks and best Regard's
Jamil
Message 13 of 24
Balaji_Ram
Hi Jamil,
You may need to check the names with which the parts get saved from the earlier occurrence and get replaced in the new sub-assembly occurrence.
In the code snippet that i shared, i have simply appended "_New" to the part file names. So, this may be overwriting the part files that get created in the first copy. I haven't ensured that the new part/assembly file names are unique. You may need to tweak it to ensure that the file names are as per your naming conventions and unique.
Balaji
Balaji
Message 14 of 24
jam_bhatti
@Balaji_Ram
Yes the sub-assembly and part created unique for first occurrence and more sub-assemblies occurrences i have to do some steps manually as below:
1) change parameters for sub-assembly to getting new location and size. close model with save.
2) open Model> go to rule> find and replace the file name "_New{0}" to "_New1{0}" Then  click OK
for every new unique occurrence needs these above steps. if its by code it will be smooth compliance.
Message 15 of 24
Balaji_Ram
Hi Jamil,
I do not understand the first manual step that you mentioned.
But the second one which requires new file names to be generated automatically can be achieved quite easily.
		Dim cnt As Integer
		cnt = 1
		While System.IO.File.Exists(newSubAssyPath) = True
			newSubAssyPath = System.IO.Path.Combine(New System.String() {fi.DirectoryName, fi.Name.Replace(fi.Extension, [String].Format("_New{0}{1}", cnt, fi.Extension))})
			cnt = cnt + 1
		End While
		MessageBox.Show(newSubAssyPath)
Balaji
Balaji
Message 16 of 24
jam_bhatti
@Balaji_Ram
YES THANKS ITS WORKING FINE NOW.
one more thing if you add in this snippet. when disabling some parts in a sub assembly as suppressed. its not woking and encounter the error.
I have trying different way but can't resolve.
oAssyDoc = doc
oSubAssyOcc = oAssyDef.Occurrences(9)
If    oSubAssyOcc.Suppressed = True Then
    oSubAssyOcc.Delete
    Dim cnt As String
    cnt = NN
        newSubAssyPath = System.IO.Path.Combine(New System.String() {fi.DirectoryName, fi.Name.Replace(fi.Extension, [String].Format("_{0}{1}", cnt, fi.Extension))})
        MessageBox.Show(String.Format("Error copying the SubAssembly file {0}{1}", oSubAssyDoc.FullFileName))
        Return
                newPartPath = System.IO.Path.Combine(New System.String() {fi.DirectoryName, fi.Name.Replace(fi.Extension, [String].Format("_{0}{1}", cnt, fi.Extension))})
                MessageBox.Show(String.Format("Error copying the part file {0}{1}", oPartDoc.FullFileName))
                Return
            MessageBox.Show(String.Format("SubAssembly {0}{1} inside a SubAssembly. This case is not yet handled.", oSubOcc.Name))
            Return
    Next
    oPosition.SetTranslation(oTG.CreateVector(0, (NELV-SF)/10, 0))
    Next
Message 17 of 24
Balaji_Ram
Hi Jamil,
When some of the parts are suppressed, we wont get its definition. So, we can temporarily unsuppress them while copying the parts.
Here is the modified code.
			Dim wasSuppressed As Boolean
            wasSuppressed = False
            If oSubOcc.Suppressed Then
                oSubOcc.Unsuppress()
                wasSuppressed = True
                Return
		 	If wasSuppressed Then
            	oSubOcc.Suppress()
            Return
    Next
With this, the copied sub-assembly will have all its parts unsuppressed although the sub-assembly from which we copied it had the same parts suppressed. If you choose to suppress the parts even in the new sub-assembly, you can keep track of the part names and suppress them after the copying is done.
Hope this helps.
Balaji
Balaji
Message 18 of 24
jam_bhatti
@Balaji_Ram
Hi
Applying the copy rule sub-assembly LOD is going to deactivate and the copy sub-assembly LOD is also deactivated. I don't know why LOD is going to deactivate and how to fix it . due to this i can't able to do finally suppressed parts again using code the end of copy rule snippet.
If NBL1 = True Then
Component.IsActive(MakePath("Nozzle-01_" & NN & ":1", "Blind-01-01_" & NN & ":1")) = True
Component.IsActive(MakePath("Nozzle-01_" & NN & ":1", "Gasket-01-01_" & NN & ":1")) = True
Else
Component.IsActive(MakePath("Nozzle-01_" & NN & ":1", "Blind-01-01_" & NN & ":1")) = False
Component.IsActive(MakePath("Nozzle-01_" & NN & ":1", "Gasket-01-01_" & NN & ":1")) = False
Message 19 of 24
Balaji_Ram
Hi Jamil,
I dont see any issue with LOD automatically deactivating. Here is the code that i am using which includes the suppressing of parts that were already suppressed in the sub-assembly being copied.
oAssyDoc = doc
    oSubAssyOcc.Delete
    Dim cnt As String
    cnt = NN
        Return
	Dim oList As Collection = New Collection
                Return
				oList.Add(newPartPath)
            	oSubOcc.Suppress()
            Return
    Next
    ' Replace the parts in the New Sub-Assembly and suppress them if needed
			' Suppress if needed
			For Each PartName As String In oList
				If (PartName = newPartPath) Then
					oSubOcc.Suppress()
					Exit For
			Next
    Next
Here is a video recording showing the results :
http://autode.sk/1HrB50E
Balaji
Balaji
Message 20 of 24
jam_bhatti
Hi Balaje,
Thanks for help and done great job that cover my needs.
Jamil
