Autodesk Inventor Interop reference older version
bradeneuropeArthur
Mentor Mentor
Message 1 of 10
bradeneuropeArthur
My question is how can I program in vb.net for an older version of inventor with a newer version inventor.
I want to create a add in referenced to the Autodesk.Inventor.Interop.dll inventor 2017, but I am having installed inventor 2018.
How can I do that?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Replies (9)
Message 2 of 10
Frederick_Law
Most of the old dll are installed at: C:\Windows\Microsoft.NET\assembly\GAC_MSIL\Autodesk.Inventor.Interop
Delete reference to 2018 and add reference to another dll.
Message 3 of 10
bradeneuropeArthur
Super.
Did not know that.
Now I can program also for older releases.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 4 of 10
Frederick_Law
I maintain few version for my addin: 2015, 2017 and 2018.
Open the project, change the reference dll, compiled file location and save it with a new file name.
If there is changes then I'll need to compile it 3 time.
I believe there is better, faster way to do this but I haven't figure it out yet.
A batch compile script and a installer to copy would be great.
I think I can set my folder to be the same as the ApplicationPlugins folder.
Message 5 of 10
woodstylee3
Message 6 of 10
bradeneuropeArthur
Do you no the example code for inventor versions like 2016 2017 2018 versions of inventor?
I mean how to do that?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 10
bradeneuropeArthur
eneurope
7:42 AM |
Do you know the example code for inventor versions like 2016 2017 2018 of inventor?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 10
Frederick_Law
My 2012 addin works in 2015 and up.  UI is Ribbon only in newer version.  Basically I use the same VS template.
Even Examples in Inventor Help are the same over the year.
Only different is new features in newer versions.  The What's New section in each year's help will have new API features.  As long as you don't use new features, the addin will run in older version.
You'll have error when compile if you use any newer functions.
In the .addin file you need to set the version:
  <!--Created for Autodesk Inventor Version 21.0-->
  <SupportedSoftwareVersionGreaterThan>21.0</SupportedSoftwareVersionGreaterThan>
Message 9 of 10
bradeneuropeArthur
But i am not deploying the interop version with my add
in.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 10
Frederick_Law
No, you don't.
As long as the addin is compile with the correct reference it'll run.
Inventor is backward compatible.  2016 addin will run in 2018.  Unless it try to modify Library location Smiley Frustrated
2017 installed 4 old interop: 17-20.  So you should be good with 2016 (20.0).
