API add partslist on drawing
Message 1 of 12
I'm trying to create a partslist on drawing. I managed to achieve this for getting the partslist for the first object on sheet (got the rule from Programming help).
Public Sub CreatePartsList()
    On Error Resume Next
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the active sheet.
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    ' Set a reference to the first drawing view on
    ' the sheet. This assumes the first drawing
    ' view on the sheet is not a draft view.
    Dim oDrawingView As DrawingView
    Set oDrawingView = oSheet.DrawingViews(1)
    ' Set a reference to th sheet's border
    Dim oBorder As Border
    Set oBorder = oSheet.Border
    Dim oPlacementPoint As Point2d
    If Not oBorder Is Nothing Then
        ' A border exists. The placement point
        ' is the top-right corner of the border.
        Set oPlacementPoint = oBorder.RangeBox.MaxPoint
    Else
        ' There is no border. The placement point
        ' is the top-right corner of the sheet.
        Set oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width, oSheet.height)
    ' Create the parts list.
    Dim oPartsList As PartsList
    Set oPartsList = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint)
End Sub
But this does not serve my need, I want to get the partslist from the first object on sheet1. How can i adjust to do this?
Or can i just replace "oDrawingView" with my object location? (tried it but this does not generate anything.)
Replies (11)
Message 2 of 12
BrandonBG
Try changing
to
  Set oDrawingView = oSheet.DrawingViews.Item(1)
Brandon
Message 3 of 12
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 10712 StartFragment: 314 EndFragment: 10680 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
    Dim oSheet As Sheet
    oDrawingView = oSheet.DrawingViews.Item(3)
    Else
        oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width, oSheet.Height)
This still gives me the first view on the current sheet, but this is not the one i need.
I'm trying to make a "production book"
Page 1 has the full assembly on it, and all the other sheets just have single parts that need to be made before assembly.
But for each sheet i want to make a reference to the partslist of the main assembly.
So i want to add a partslist from sheet 1,object 1 on sheet x (and then filter the parts i need based on item number).
Message 4 of 12
dominiek_vanwest
This is a couple of months old, but I just came across this.
If I understand it correctly: you want a partslist on sheet x that references the assembly on sheet1?
If that's the case you should make 2 sheet variables.
Dim oSheet As Sheet
Dim oMainSheet As Sheet
oMainSheet = oDrawDoc.Sheets.Item(1)
And then change this too:
oDrawingView = oMainSheet.DrawingViews.Item(3)
Message 5 of 12
MechMachineMan
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.Sheets.Item(1) 'Change the 1 to be whatever sheet you want.
    Set oDrawingView = oSheet.DrawingViews(1) 'The first view is usually the best one to use, so keep this.
    Else
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 6 of 12
GosponZ
'activating this command part list table will be inserted and will sit on top of title block on lower right corner
' add partslist table
oDrawDoc = ThisDoc.Document
    Dim oSheet As Sheet
    Dim oBorder As Border = oSheet.Border
Else
minXpoint = oSheet.TitleBlock.RangeBox.MinPoint.x
minYpoint = oSheet.TitleBlock.RangeBox.MaxPoint.Y
maxXpoint = oPlacementPoint.x
dPointx = oSheet.PartsLists.Item(1).RangeBox.MinPoint.X - minXpoint
dPointY = oSheet.PartsLists.Item(1).RangeBox.MinPoint.Y - minYpoint
maxYpoint = oPlacementPoint.Y - dPointY
Dim newmin, newmax As Point2d
newmin = ThisApplication.TransientGeometry.CreatePoint2d(minXpoint, minYpoint)
newmax = ThisApplication.TransientGeometry.CreatePoint2d(maxXpoint, maxYpoint)
oSheet.PartsLists.Item(1).Delete
oPartsList = oSheet.PartsLists.Add(oDrawingView, newmax)
Message 7 of 12
dominiek_vanwest
MisterZS,
Your post is just how to add a partslist to a drawing, right?
But that's not the question of the topic starter, he already knows how to add a partslist, but he wants a reference to another sheet.
Message 8 of 12
Thanks. Removed the (Set) and it worked fine. So many Places to look
Message 9 of 12
o.sassen
Hi All,
I don't get it right. i still get an error on: Newmin, "Compile error: Agrument not optional"
What can I do?
minXpoint = oSheet.TitleBlock.RangeBox.MinPoint.X
maxXpoint = oPlacementPoint.X
Dim newmin As Point2d
Dim newmax As Point2d
End Sub
Message 10 of 12
dgreatice
Hi.
I think do you want to create new Part list base on Main Parts (example: 2 item inside) list in Sheet 1 (example named Assy:1) --> it become Detail Part list per item per sheet (new Part list each item from main partlist then save in another sheet (With new sheet)) ?
are my assumption are right?
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 11 of 12
JamieSENG
I use this with success...
'iLogic rule CreatePartsList places the parts list
'at the top right corner of the border if one exists,
'else it is placed at the top right corner of the sheet.
Try
'drawing document should be active,
'the first view should be tied to the assembly model
'set a reference to the active sheet
'set a reference to the sheet's border
'a border exists. The placement point
'is the top-right corner of the border
If oBorder IsNot Nothing Then
Else
'there is no border. The placement point
'is the top-right corner of the sheet
'set a reference to the first drawing view on
'the sheet. This assumes the first drawing
'create the parts list
Dim viw As DrawingView = oDrawDoc.ActiveSheet.DrawingViews.Item(1)
oDrawDoc.Sheets(1).PartsLists.Add(viw, oPlacementPoint, PartsListLevelEnum.kStructuredAllLevels, Nothing, 1, True)
Dim oPartsList1 As PartsList
oPartsList1 = oDrawDoc.ActiveSheet.PartsLists.Item(1)
'If oPartsList1 Is Nothing Then Resume Next
oPartsList1.Sort("PART NUMBER")
oPartsList1.Renumber
oPartsList1.SaveItemOverridesToBOM
Catch
'if an error occurs message box appears
    MessageBox.Show("Something went wrong!" & vbLf & "Create Manually", "Oops!!")
End Try
Message 12 of 12
GosponZ
ok this one will put parts list on left upper corner
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 11332 StartFragment: 314 EndFragment: 11300 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
Sub Main()
'Declare local variables
Dim oSheet As Sheet
Dim oStyle As String
Dim oPlaceX As Double
Dim oPlaceY As Double
'initialize variables
'user input - select parts list style
'oStyle = InputListBox("Choose Parts List Style", MultiValue.List("PartsListStyle"), "Custom Parts List (ANSI)", "Parts List Style", "List Prompt")
'create parts list
oPartsList = oSheet.PartsLists.Add(oDrawingView, oBorder.RangeBox.MinPoint)
'oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item(oStyle)
'reposition parts list to top left
oPlaceX = oBorder.RangeBox.MinPoint.X + (oPartsList.RangeBox.MaxPoint.X - oPartsList.RangeBox.MinPoint.X)+(1.27)
oPlaceY = oBorder.RangeBox.MaxPoint.Y
oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(oPlaceX,oPlaceY)
oPartslist.position = oPlacementPoint
End Sub
