I have taking a license report and on this report there is a lot of appications called ACAD Private XX.X.
We have a lote of users who has different AutoDesk applications but all those users also have this ACAD Private.
What is ACAD Private and do the users need this when they have a AutoDesk license.
Can we remove it from the the machines and if how on Windows 10?
Solved by m_latz. Go to Solution.
Solved by fihansen. Go to Solution.
Where are you seeing this?
what report are you talking about?
DarrenP
We have Flexera License Manager and if we choice AutoDesk products there comes a lot of AutoCAD products where we have license but there is many users who has this ACAD Private, ACAD Private 22, 23, 23.1?
The AutoCAD installation consists of several MSI packages:
And the "ACAD Private" package is one of the msi packages contained in a full AutoCAD (Aca, Mec, Ele, ...) installation.
If there is any AutoCAD installed on your pc you can uninstall this msi package.
Is your question answered ?
regards
Markus
OK, i will try to uninstall it. But my question about "What is ACAD Private " is not answered. What is the use of it?
"What is ACAD Private" ?
It is a msi installation package which is a required part of an AutoCAD installation. The msi package installs required files for AutoCAD, without this msi package AutoCAD can't run.
The "use of it" is, that the msi package installs required files for the AutoCAD program.
Example from real world: "What are the wheel bolts on my car used for ?" Try to drive without ...
regards
Markus
Hi @afr7VUTAW,
It's included in the full installer for AutoCAD, which you can find at https://manage.autodesk.com/ or https://ava.autodesk.com/
