Installation & Licensing
Upgrade Autocad LT 2016 to 2021
2 REPLIES 2
meirbitXEY88
1901 Views, 2 Replies
I have autocad lt 2016 and I need to upgrade it to 2021.
Can I install Autocad LT 2021 without removing 2016 or should I uninstall it?
 Second question: I'm working with the classic mode instead of the ribbon, How can I keep/save the setting of the Classic tool and moving it to the new Version (2021)?
Thanks in advanced
Meir
2 REPLIES 2
pendean
in reply to: meirbitXEY88
Yes, both versions can safely be on the same PC for as long as you want.
The Classic Workspace went away, but you can recreate it anytime you want since many of those old toolbars are still around.
HTH
@meirbitXEY88
It all depends...   Are you just subscribing to 2021?  Or did you use the 2016 version to get a reduce cost on 2021?
See this as well https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Au...
Mark Lancaster
Administrator Productivity
