I have autocad lt 2016 and I need to upgrade it to 2021.
Can I install Autocad LT 2021 without removing 2016 or should I uninstall it?
Second question: I'm working with the classic mode instead of the ribbon, How can I keep/save the setting of the Classic tool and moving it to the new Version (2021)?
Thanks in advanced
Meir
Solved by Mark.Lancaster. Go to Solution.
It all depends... Are you just subscribing to 2021? Or did you use the 2016 version to get a reduce cost on 2021?
See this as well https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Au...
Mark Lancaster
& Autodesk Services MarketPlace Provider
