Installation & Licensing
Unable to change install path when installing AutoCAD
15 REPLIES 15
Message 1 of 16
1897 Views, 15 Replies
I am trying to install AutoCad on my pc but it won't let me change the install path all of it is grayed out.
On left, it says that it is installed if it is installed where can I get a shortcut?
Previously I tried to install it on my external d: drive but it failed so I uninstalled it and tried again now without the d: drive connected but it still says that it wants to install it there. (I  have tried with d: drive connected and it still won't let me change the path as everything is grayed out)
I have tried searching on the internet for help but everyone else's problems are with storage capacity.
@Anonymous Topic Title has been changed for better findability by @Tiana_Y
Labels (1)
  • Help
15 REPLIES 15
Message 2 of 16
mdavis22569
mdavis22569
Is your OS on the 😧   Likely why, it needs to install on the OS drive.    You can extract it to the other drives ( and not the C:/Autodesk that it defaults) ...
Mike Davis
Mike Davis
Message 3 of 16
in reply to: mdavis22569
My OS is on c: drive all the problem is in the pathing.
From what I understand when you make path it will say how much free space is on the drive on the right of text box, right now in the box it just shows d: and that there is 360gb free but the thing is 360gb is on my c : drive.
I would love to understand how can i change path as i cant even click in the text box, browse is locked just like install button.
Message 4 of 16
pendean
pendean
Community Legend
Community Legend
Your screenshot says he program is already installed.
A done deal.
Finished. Complete.
You cant change anything after the fact.
HTH
A done deal.
Finished. Complete.
HTH
Message 5 of 16
in reply to: pendean
If that is the case then where can i find run exe? It didn't make any shortcuts on desktop and cant find any autocad program in windows search.
Message 6 of 16
mdavis22569
mdavis22569
it should be where you extracted it .. however by default it's in the C:/Autodesk folder
Mike Davis
Mike Davis
Message 7 of 16
Went to c:/autodesk folder there are two autocad folders:
1. AutoCAD_2021_English_Win_64bit_dlm
2. ends with wi_en-us instead of _dlm
Noone of them contains a program file both only contain setup file that i can run. If I run them they show the same thing that is in picture.
Message 8 of 16
So for more context this is what i did:
1. Went to this site www.autodesk.com/education/edu-software
2. Clicked on arrow at rightand clicked download (file was 1.6gb)
3. Ran the file which was supposed to instal the autocad
Message 9 of 16
mdavis22569
mdavis22569
Ran or downloaded and extracted?
Mike Davis
Mike Davis
Message 10 of 16
Hmm at first i thought that it is a exe file so here it is:
1. I downloaded the 1.6gb file
2. I ran it and it extracted the autocad_2021_.... in the c:/autodesk folder
3. When AutoDesk AutoCad installer is open I click install - > select country - > problem picture
Message 11 of 16
pendean
pendean
Community Legend
Community Legend
>>>...I ran it and it extracted the autocad_2021_.... in the c:/autodesk folder...<<<
Then you either have this here or you deleted it or you are looking in the wrong spot: do you have file extensions hidden? Or are you on a MAC?
Message 12 of 16
This is exactly what is driving me crazy i am doing everything you are saying. I am on PC I, downloaded PC version, I clicked on the same setup and it asks me to install it, when I get to install part it doesn't let me change the path or install at all.
Message 13 of 16
mdavis22569
mdavis22569
You can't change it .. it has to be on the OS drive that's it
Mike Davis
Mike Davis
Message 14 of 16
I understand it. My OS is on c: drive, I WANT TO install it on c: drive yet it shows d: by default I cant click in the window to change it to c: drive (which is my OS drive) i cant click browse to change it to c: drive.
d: drive is my external storage which is not event connected when I try to install program so there is no reason for it to show up.
I have tried to install it when its connected and when it is not result is the same.
Message 15 of 16
Quick update apparently it doesn't install autocad itself only the App Manager, Apps plug-in and desktop app. How do I get AutoCad itself?
Message 16 of 16
pendean
pendean
Community Legend
Community Legend
Perhaps you need to post a video of your entire installation process from start to finish, if taking your computer to a repair shop for tech support or consulting with an IT specialist in your office/area is not an option.
Administrator Productivity
